still using lube control
Old May 12, 2006
not so much the fp anymore cause i'm lazy, but i always keep up with the lc. i got an oil change today and on the way home the engine sounded horrible grumbling and making rattle sounds. i quickly put in some lc and after a bit of driving its so smooth again. i think the motors hooked on it now lol. great stuff. i've been using almost a year now with no problems.
Old May 12, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
I just changed my oil yesterday, after 6,000 miles. Eventually I'll get around to buying some lc and giving it a try...
Old May 12, 2006
ya i usually let mine go 5.5k each time. oh and dont use the lc til the engine breaks in completely. I dont know exactly, but i would say not til 20k just to be extra sure.
Old May 12, 2006
I'm at 86,000....I went 6,000 miles between oil changes
Old May 12, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
nice find
Old May 13, 2006
Jrfish007's Avatar
Interesting...
Gearbox, have you gotten the oil tested yet?
Old May 13, 2006
no i should've tho crap. next time
Old May 14, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
man I need to get some more lc I got like 3 to 6 oz. left....goes quick when you put it in like 3 or 4 cars hehe
Old May 14, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I still haven't noticed anything from the FP. Maybe a 1 mpg increase, but that could easily be due to driving habits.
I've noticed that when I first used LC, my oil got real black real quick. My engine might run slightly smoother, but it could be in my head.
Old May 14, 2006
thats good it means its suspending all the carbon in the oil til you change it. over time it should be getting less black.
Old May 15, 2006
Jrfish007's Avatar
Or one F150.... stupid thing takes 7 quarts of oil, and then people wonder why I by 10 gallons of oil when it goes on sale. Then I have my chevy too, that takes 6 quarts, then 2 civics, but both of those combined take less then my F150... blah, I feel like I have an oil well gone bad in my drive way sometimes.
Old May 15, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
my friend's aunt's expedition takes 16 qts of oil or some ridiculous amount like that
Old May 15, 2006
Most likely a Diesel...Ford Diesels take 15-16, Dodge Cummins take anywhere from 11 for olders, to 13-14 for newers, and Chevy's take 10 on the dot for the Duramax motors
After I get the Moroso oil pan and relocate the filter on my Talon, It should take around 8 qts to fill it up
Old May 15, 2006
Jrfish007's Avatar
Yeah, diesels take quite a bit of oil, but can use that oil for quite some time considering most of them stay well under 1,500 RPM and redline around 3500
Old May 15, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
ah, yes .. it is a turbo diesel ;P
Old Sep 4, 2006
its been well over a year using both of these and nothing bad happened, mileage is still great, engine still sounds like new.
Old Sep 4, 2006
shroomster's Avatar
same here....just I need to order some more lc20.....three cars and the little bottle doesn't fair well when you add it to the tranny, p/s, and the engine...
Old Sep 6, 2006
scizod's Avatar
scizod is an unknown quantity at this point
group buy.....
by any chance do you think there will be another group buy on this stuff?
Old Sep 6, 2006
did you try those coupon codes? they might still work.
FP60GALRTN05
LC20GALRTN05
Old Sep 6, 2006
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
It works?!
so this stuff really works...?!?!?!??!!?!?
Old Sep 6, 2006
eh, i used to only get 38mpg on highway before, then after a month of using said products, i get around 42. engine sounds better, feels smoother at hi speeds, and car has a tad more power. i even put some in my auto trans, after 10k miles i drained the fluid and there was black sludge on the drain bolt that i never got changing the fluid before. so yes i believe it does what it promises.
Old Sep 6, 2006
trust me you need a gallon of lc too and it wont really go bad. the fp though you really need to shake well before each use because stuff settles to the bottom. the lc you add around 3.7 ounce each oil change and 1 oz every 1k miles. ive used quite a bit already. its alot more expensive to get the smaller amount than the gallon.
Old Sep 6, 2006
i would get two bottles, one for each product
Old Sep 6, 2006
shroomster's Avatar
yeah the lc20 gets used in more applications than the fp (just gas) so it goes alot faster IMO...well like I said earlier though cuz I use it in three cars though..so that may be why for me at least....I just need money heh....
Old Sep 6, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
hahah u have no idea how much i laughed. Its got Car Crack in it....ur cars addicted....its a problem
Old Sep 7, 2006
oh i know, if i dont add it right away (like after oil change) it gets pissy and sounds/drives terrible. i can tell big difference after changing oil and not using the fp for a while. seriously it needs this stuff now to work right.
Old Sep 7, 2006
well ya i guess, it does better with the drug than without, you just gotta keep feeding it
Old Sep 7, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I've been using FP60 in my 01 reliegiosly, every fill up, since I got the stuff last year, bottle lasts a long time. Car runs smooth no CEL ever and i'm using regular.
Old Sep 11, 2006
VicDawg's Avatar
VicDawg has a spectacular aura aboutVicDawg has a spectacular aura aboutVicDawg has a spectacular aura about
I am actually impressed. I decided to try fp60 after reading a few threads. I bought the 32oz to try in my truck. It’s a gas hog so I figured any improvement would be more noticeable than in my civic. Best I ever get normally is 18 mpg hwy. After 3 tankfulls, I avg 20 mpg hwy. 2 mpg doesn’t sound like a lot but that is a solid 10% improvement. Not bad imo. Hope the same for my civic.
I just ordered a gallon more. Thanks for the coupon code Gearbox!
robjcivic
Mar 12, 2017 12:10 PM
Klame9420
Sep 7, 2015 10:03 PM
99BoostedSi
Sep 7, 2015 04:49 PM
