To all the peeps looking for a cd player!
Old Jul 1, 2005
Fuschiacivic02's Avatar
Cutie Wit A Bootie!
Fuschiacivic02 has a spectacular aura aboutFuschiacivic02 has a spectacular aura aboutFuschiacivic02 has a spectacular aura about
$220 Brand new in box!
Satellite Radio Ready: Yes
Satellite Radio Ready: The receiver is compatible with optional tuners that will receive digital satellite radio broadcasts such as Sirius or XM Satellite Radio. The digital satellite service must be subscribed to separately.
RMS Power Output: 18 Watts
RMS: Root Mean Square is a formula that provides a reasonably accurate means of measuring and comparing continuous AC power. The use of this measure is preferred when matching system components, like amplifiers and receivers.
Preamp Voltage: 2 volts
Preamp Voltage: Refers to the strength of the pre-amp outputs. Generally, higher output voltages make it easier to get a cleaner and a more noise free signal delivered to amps and pre-amps.
Subwoofer Preamp Outputs: Yes
Preamp Output: Typically found on headunits, a preamp output provides low level, high quality audio signal for use with external amplifiers.
Maximum Power: 50 Watts
Maximum Power: The amount of power a speaker is estimated to handle during a brief high-intensity musical burst. Since this can vary with both frequency and amplitude, it is a much less accurate way to judge speaker durability and performance than RMS.
DIN: 1
DIN: Acronym for Deutsche Industrie Norm (Deutsches Institut fuer Normung), the German standardization body. A world reference standard for the mounting parameters of many common receivers ( Head ends) as well as other types of cables and equipment.
Changer Control: Yes
Changer Control: Receivers with changer controls operate same-brand/compatible CD or MD multi-disc changers.
CD Text: Yes
CD Text: The receiver can display disc and song title information contained on CD-Text encoded discs.
Built-in EQ: Yes
CD-R/CD-RW Compatible: Yes
Remote Control: Yes
Detachable Face: Yes
Features
CD receiver with built-in amplifier (18 watts RMS/50 peak x 4 channels)
Detachable, fold-down face (with silver and blue cosmetics and variable button color)
Plays audio CDs, CD-Rs and CD-RWs including discs burned with MP3 and WMA files
Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
MaxTune tuner
12 FM/6 AM presets
source tone memory
XM and SIRIUS Satellite Radio controls
CD changer controls for Alpine Ai-NET changers only
front, rear and subwoofer preamp outputs
clock
wireless remote
CEA-2006 compliant amplifier
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
Warranty: 1 Year warranty (MANUFACTOR)
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
