2002 CR-V, Removing the fender to replace windshield fluid reservoir
Old Nov 1, 2016
Jasinsk7's Avatar
Jasinsk7 is an unknown quantity at this point
Hi there,
I'm attempting to remove my front fender to replace the windshield reservoir in my 02 CR-V, but having never done it before, I'm hoping to get a few tips so I don't break the molding, etc.
Any tips or directions to threads with helpful pictures on 1) Removing the fender and 2) replacing the reservoir?
Thanks!
Cheers,
Briana
Old Nov 1, 2016
Re: 2002 CR-V, Removing the fender to replace windshield fluid reservoir
Step 1: If you had a decent service manual, it should let you know the fender does not get removed.
Step 1: The plastic wheel well liner (splash shield) gets removed in order to access the reservoir.
I saw one of those a couple weeks ago that had cracked and would pee washer fluid straight out between the door and the fender. A few dabs of RTV gasket sealer and a few hours to allow it to cure fixed the leak for nearly free.
