Can I disable the AC in defrost mode? -2nd post have the answer.
Old Dec 29, 2015
aleks08's Avatar
aleks08 is an unknown quantity at this point
Question Can I disable the AC in defrost mode? -2nd post have the answer.
Is this default or is my car just ****ed? This only happens for the front windshield, every other setting I can actually turn off the AC, but not when defogging the front windshield. 2002 sedan non-Si, stock everything
Old Dec 29, 2015
maxtierney's Avatar
EM2ti
Re: AC always stays on when I turn on the fan for the front windshield.
With your fan and key off, press/hold the Recirculate and A/C buttons down. Turn the key to the ON position. Keep pressing until the Recirc light flashes/extinguishes. Release. Done. You can now switch the A/C off after turning on the front defog.
Old Jan 1, 2016
aleks08's Avatar
My man! Thank you, it worked.
If anyone else is looking to do this, I had to do the above procedure twice. The 1st time the recirculate light stayed on. I also changed the fan setting in between the 1st and 2nd try but I don't think that makes a difference.
Also by OFF he means key position I and ON is key position II.
