Silly? which ATF question
Time to drain fill my Wifes' 04 with 50K miles... transfluid.
Dealers ZW1 is 11$ a jug. I'm cheap by nature
ANY.. point in buying a Gallon of Mobil Trans fluid ?? label claims ZWI compatible.
Or just a foolish try at saving 10$ ?
Re: Silly? which ATF question
Thank you.. Just came back from the dealers.. a bit lighter of wallet though :-) Didn't realise that Ali drain plug washer was 5$ tho !.
Slightly smaller Oil one is 90 cents.
The Honda ATF is DW-1. Only use this ATF. You might want to do another drain and fill since you only have 50K and most likely have the old Honda ATF Z-1 in the trans. DW-1 is synthetic.
The legs in the public bathroom stall
I have been told by Honda corporate tech staff that the DW1 has much much better lubrication properties compared to the Z1 and that is the major difference between them. I personally have never seen anything that refers to DW1 as synthetic, but I will spend a couple minutes looking later at the release notes from 2009 to see what it says about it.
I checked the old service news and it doesn't say anything about my lubrication theory or synthetic base stock. All it says in the release news was that it was a better performing fluid when cold which would result in increase fuel economy.
Received 1,442 Likes
Rep Power: 338 Re: Silly? which ATF question
not a DIY article, so moving to correct section
