got a squeaky clutch? I fixed mine today **pic added**
#91
Rep Power: 0 Re: got a squeaky clutch? I fixed mine today **pic added**
Damn, the noise is back I see. I did a good job of cleaning her up and lubeing her too Guess I'll just have to live with it
#92
where are you guys accessing your clutch master cylinders?? from inside the car?? From what I can tell, I can not easily access mine from under the hood. I can hardly see it - let alone get to it.
Can anyone post up a picture of the master cylinder everyone is talking about? Thanks!
#93
Rep Power: 210 Re: got a squeaky clutch? I fixed mine today **pic added**
Hope these help you...(my first time posting pics...be nice to me)
Here's a pic of the slave cyl. (not the clutch master cyl. )for location reference...
Heres one of the actual slave cyl. up close...
Find the whole schematic HERE and number 7 is the slave cyl. as seen below
Free shot of my bay....
Last edited by HondaCivicCat; 01-13-2008 at 04:20 PM. Reason: Fixing stuff...pwnd for not paying attention
#94
...nevermind that last post. i was able to get to it, take it apart, clean it, and apply joint grease to the ball joint. worked like a charm!
#95
1 Post
Heres one for location reference...
Heres one of the actual thingy...
Heres a schematic from majestic honda
first pic is actually the slave cylinder, so is the second, the schematic from majestic is the correct one, but the clutch master cylinder is actually bolted to the brake booster, along with the brake master cylinder
#96
^^^thanks, you're right...I put up the wrong schematic (should have put up the slave cyl schematic) and called the slave cyl. the clutch master.
It seems that from the beginning of the post people were calling the slave cyl the clutch master cyl. which is what initially got me confused. But the original DIY was to lube up the slave cyl. where it connects to the release fork so that is what I was trying to take pics of but was using the wrong terminology like in the first few pages.
I'll edit the previous post with the correct schematic and correct terminology.
Thanks for pointing this out greeen01civic4d; could have caused a lot of confusion
<<<<<pwnd for reading the first post only
#97
1 Post
hey no prob man, i have the actual copy of honda's pdf for the TSB that covers this if u want it, hit me up with a pm containing ur email, and ill email it to u
#98
Rep Power: 450 Re: got a squeaky clutch? I fixed mine today **pic added**
just to let you guys know the thread starter said make sure you have clutch fluid just in case, there is no thing as clutch fluid...you add dot3 brake fluid to that little canister for your clutch, not tranny fluid or anything else
#99
1 Post
how about wd40, does that work, or axle grease maybe.... lol, thank you captain obvious... j/k all u gotta do is read the cap, itll tell ya, good point tho
#100
yea but obviously the thread starter didnt read the cap so you never know lol
#101
1 Post
Instead of using white lithium grease. Don't you think it would be better to use molykote grease (molybdenum disulphite)?
This is actually the grease honda use between brake pads and calipers to stop squeaks.
It is much more resistant to pressure and temperature as compared to lithium grease.
Maybe that could be a permanent solution to clutch squeaking problems related to slave cylinder.
#102
I know this is an old thread, but it's still very much relevant. How do I check the clutch fluid level, what am I looking for?
thanks
thanks
#103
Rep Power: 244 Re: got a squeaky clutch? I fixed mine today **pic added**
The clutch fluid reservoir is the smaller white with grey cap container (next to the brake fluid reservoir) at the top right of the pic (provided above by HondaCivicCat):
#104
This thread saved my sanity! My clutch was squeaking like crazy (interior and under the hood). I sprayed the interior one down with white lithium grease and lubed the slave cylinder ball joint with conventioal (GLOPPY) grease. No more squeak! On a side note (pardon the fact that I am not a mechanic), if you remove any piece, specifically the ball part of the joint from the slave cylinder, your clutch will lose pressure. No worries, though, it will regain pressure once the ball is securely back in place.
#105
This needs to be a sticky. And btw, does anyone have updated pictures on how to do this? Getting real annoying to listen to in my car~!!!
#109
ok i just did this today and took pics for everyone to enjoy...
first you're going to want to unhook your 02 sensor wires from their mount (this was done on a dx but i believe the ex wires connect at the same bracket)
next you're going to unbolt that bracket and the bolt next to it, these are what hold the clutch piston to the block.
look at pics 1-3 for a good look at where the black cover is the piston is right next to it i just didn't take a pic of it... picture 3 is from under the car. jacking the car up is not necessary but it made it a lot easier to get the under side all lubed up imo...
next pull off the black dust cover and you should see this... (see pic 4) pic 4 is also from under the car
now just use as much white lithium grease as possible... i actually did it once form top once from bottom then bolted it back together and pumped the clutch a few dozen times and then did it from the top again... pic 5 is how it looked after i lubed it all up
when i unbolted the piston i actually pulled the rod out away from where it contacts the shift fork... and it came out of it's boot and i thought i screwed it up but it actually just sits in there... so i sprayed the top of it and where it sits on the shift fork before reassembling it all...
and reassembling is the hardest part because you have to get that rod to sit in the piston and on the shift fork with the black dust cover on it and keep it there while you thread the bolts in...
but it was totally worth it... no more annoying squeaking!!!
p.s. i also sprayed some of the grease on the rod where the clutch pedal goes into the master cylinder from inside the car because that is a typical spot for squeaking as well as the joint for the pedal.
i hope i covered everything please ask me any questions if i forgot something...
#110
Just a side note
What Silverem2 did worked perfectly well and requires no working under the hood.
Simply get a can of white lithium spray with the little straw and pop off the two panels under your steering wheel. They come right of with twist locks so its very easy. This will allow you access to the clutch pedal.
If you press the clutch pedal and look at the rod that goes through the firewall a hole opens up around the rod as the pedal is pushed.
Simply push the pedal in and shoot the grease into the open area until it starts to pour out. Do the top and the bottom and your all set. Give the pedal a few pushes and your good to go.
Thanks :]
#112
Low and slow!
1 Post
Rep Power: 190 Re: got a squeaky clutch? I fixed mine today **pic added**
I want to do this. Does it require that I disassemble the dash under the steering wheel, or can I just get on my knees and look up? Whelan says I need to remove two panels from underneath my steering wheel (which by the way, can I literally just pop them off, or do I need a screwdriver?), but the other three posters just mention doing it. I'm including a picture of what I think I am supposed to grease up with white lithium grease. Is this correct?
Thanks :]
Thanks :]
#113
I just tried spraying the rod with grease and it didn't really work. Am I supposed to stick the straw into the actual hole when the clutch is depressed in, or just grease the rod? Do I need to remove the panels?
Or do I need to actually do some work under the hood? My neighbor just said he had that problem and said that I had to grease the clutch somewhere under the hood. I'm assuming that the problem is much like this one:
We tried looking for it, but couldn't find it.
Is it possible that one of these is the solution?
Also, how bad is the squeaky clutch for your car anyway?
I fixed my squeak last night, it was under the hood near the clutch cylinder. I didn't even have to unbolt anything. I just took off the rubber boot and then there was another rubber boot which I sprayed some white grease in there and it works wonders. I don't know how long it will last but it felt a lot nicer, and I didnt hear any more noise!
at the front of the L shaped boot (facing you if you are facing the car), there is a slit in the boot that you can stick your fingers in and feel around. you could easily wildly spray some lithium grease in there and probably accomplish nearly the same thing a little less precisely. in fact im pretty sure that is why that slit is there
#115
Rep Power: 262 Re: got a squeaky clutch? I fixed mine today **pic added**
Nirama,
If the squeak sounds like it is in the interior of the car when you step on the clutch, then you need to spray the lubricant in the hole.
If the squeak originates from under the hood, locate the clutch slave cylinder. To the left of it is a rubber dust cover (if you are looking down at the engine bay). Take it off and saturate where the clutch release fork meets the clutch slave cylinder.
1=Dust boot 2=Clutch slave cylinder
#118
No, the issue has to do with a metal ball joint rubbing against another surface without lube. <insert funny joke here> the sooner you can grease it up the better, but it's not going to hurt if you wait 2 weeks. I didn't grease mine for over a year and I didn't notice any real damage when I took both problem areas apart.
#119
And what happend if my clutch pedal dont have any pressure do i have to do that jajajajajaj
lol
good job, did that along time when i got pressure ojojojo
lol
#120
