DIY: ATF Change
Old Mar 29, 2004
  #31
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
this isnt really a true fluid change...since your only changing about 1/2 of the fluid....sure theres some in your pan...but theres also some in the torque converter...and if theres an a/t fluid cooler...theres more in there. ( i dont own an a/t, i dont know if it does.).
Old Jun 24, 2004
  #32
streetglower's Avatar
Originally Posted by Voiceofid
our cars do not have a atf filter, our "filter" is that magnet at the end of the drainbolt tip
the car runs smoother, and shifts more precise
before i changed it, when the car shift, it tends to disengage, and drop 2-3000rpm before it re-engage into the new gear, but now, it's sharp shifting. i hate myself for not doing it sooner
if you look at the pic of the liquid draining, that's actually dark brown, not red
i coldn't do the coolant because our car requires honda coolant, or else is corrose through the lines and such
I dont think you have to use honda coolant, I got mine flushed at kwik car and they used something else, my car works fine though.
Old Jun 24, 2004
  #33
What is the torque for the tranny bolt?
Old Jun 24, 2004
  #34
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Honda Coolant Type II is supposedly really good, it has many anti-corrosive properties. You're not going to notice a difference driving with a different type of coolant, but after 100k your water jackets and water pump will.
Old Jun 26, 2004
  #35
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Change it more often...
I changed my ATF on my Civic at 2,500 miles and 5,000 miles. Here is the reason...and feel free to challenge. When a tranny is breaking in, a lot of metal shards are being created. Theoretically, the fluid now contains metal which heats up faster than fluid thus impairing my tranny performance. When I changed it at 2,500 miles there was plenty of metal that came out. Not so much at 5,000 though. But I also plan on changing my ATF every 10,000-15,000 miles because ATF is used to not only lube but cool the tranny. I don't know about you all, but I drive my cars hard. $12 for the fluid is cheap insurance I think. Oh, and I also did this method on my last car which was a Nissan Maxima. It's tranny last till 247,000 miles. Anyone else do this?
Old Jun 26, 2004
  #36
tacheon's Avatar
tacheon is on a distinguished road
I agree. If you search around, you will find that for some undetermined reason, silicates in almost all off the shelf brands will lead to decreased water pump bearing life. Honda Type II coolant and a couple other non-silicate antifreezes out there are suitable.
Old Jan 23, 2005
  #37
triplep's Avatar
triplep is an unknown quantity at this point
is there a cheap place anyone knows of to get the stock honda atf fluid. my local dealership sells it for 7.50 a quart..which costs more than mobile 1 synthetic. Oh, and to fill it back up i guess we'll need a long funnel? or is there some other more convenient hole?
Old Jan 23, 2005
  #38
the only place you can get honda fluid is from honda. $7.50 is expensive though. One dealer here sells it for $5 something while another sells it for $3 a quart. Anyway yes just get a long thin funnel.
Old Jan 23, 2005
  #39
AzNmiKex215's Avatar
2k1civic.com O. G.
FREE!!! from my local honda buddies!!
Old Mar 17, 2005
  #40
orion_squall's Avatar
oh...
few naive questions:
what unit is a "quart"?
where is the tranny box where the bolt can be found?
Old Dec 3, 2007
  #41
carderh's Avatar
carderh is an unknown quantity at this point
Re: DIY: ATF Change
Is this procedure also good for a 2006 Civic automatic? My daughter wants me to change her tranny fluid. It looks fairly straight forward. Am I missing anything?
Old Dec 3, 2007
  #42
Re: DIY: ATF Change
should be similar, the tranny bolt may be in a different spot, and it may hold different amount of fluid, but basically its taking off the bolt, letting fluid drain, then filling it back up through the dipstick. and check the level once the car is warmed up and running.
Old Mar 4, 2008
  #43
carter's Avatar
carter is an unknown quantity at this point
Re: DIY: ATF Change
so no one recomends using somthing u can buy from Canadian Tire?
Old Mar 4, 2008
  #44
Re: DIY: ATF Change
um NO lol
Old Mar 12, 2008
  #45
Voiceofid's Avatar
End Bringer
Re: DIY: ATF Change
wow, this thread is still popular after all these years?
Old Jan 13, 2009
  #46
ross3093's Avatar
ross3093 is an unknown quantity at this point
Re: DIY: ATF Change
is there a picture showing where to place the jack stands? as I do not have a manual... and about the bolt you unscrew I understand there is a washer/gasket as well, does that need to be replaced? or can it be reused?
Old Jan 13, 2009
  #47
Re: DIY: ATF Change
yeah buy a new washer every time. its a sealing gasket. the jack points are a bit behind the front wheels, on the side of the car, where you see the longer piece of metal sticking out. i can take a pic if it helps. its exactly below the gap where the front door and fender meet.
Old Jan 13, 2009
  #48
ross3093's Avatar
Re: DIY: ATF Change
can i get the gasket at lowes? any idea on the size for it?
Old Jan 13, 2009
  #49
Re: DIY: ATF Change
no just get it from honda dealer. its less than $1 or they might even give you one free when you buy the fluid.
Old Jan 14, 2009
  #50
ross3093's Avatar
Re: DIY: ATF Change
is there a trick to getting the bolt off? mine is on there pretty good.... bent 1 wrench already....
Old Jan 14, 2009
  #51
04 Honda Civic's Avatar
Re: DIY: ATF Change
What kind of wrench are you using I think you should be using a 3/8 ratchet with no socket.
Old Jan 14, 2009
  #52
Re: DIY: ATF Change
yeah and i always need a hollow pipe on it for extra leverage. the bolt has a square 3/8 hole that only the ratchet goes in without attachments. none of the other bolts in that area have a square hole except the trans bolt.
Old Jan 15, 2009
  #53
ross3093's Avatar
Re: DIY: ATF Change
yea I was using the 3/8 wrench and a cheater pipe, I bent it pretty good, im thinking it was just a cheap POS as it looked like a wallmart no name brand... counter clockwise correct? it looks like my whole transmission was moving when I was trying to loosen it, im going to pick up a kobalt wrench today at lowes that way I can return it if I happen to bend it again...
-R
Old Jan 27, 2009
  #54
Re: DIY: ATF Change
Is the crush washer 18mm? I am about to place an order but I would feel dumb to order the wrong crushwasher
Old Feb 7, 2009
  #55
haterforever's Avatar
haterforever is an unknown quantity at this point
Re: DIY: ATF Change
people i changed my ATF and now wehen i press the X there is no acceleration. This goes on until i completely stop and change gears and start back. it happens frequently but not all the time. Its like the tranny is going. my mech says its not a problem but i don't think he understands the full problem. what do you guys think? ever experienced this?
Old Feb 7, 2009
  #56
Re: DIY: ATF Change
did you use the honda fluid? did you actually fill it to the proper level? checking the fluid with the car fully warmed up and running, it should be at the top of the dipstick. over or underfilling the trans will cause serious issues.
Old Feb 8, 2009
  #57
Re: DIY: ATF Change
^^ X2 please use Honda fluid.. the only fluid in my car thats not Honda is my coolant (Prestone 50/50) and my oil (Moblie) Do what gearbox says get the car to Operating temperature and then take it for a spin around the block. Park the car put on your park brake and go through the shifter from park all the way down and then check your fluid level. Should be in the cross hatched section. Check it wil the car in park idling and hot. If its not in the cross hatched section your fluid is off.. fix it
Old Feb 8, 2009
  #58
Re: DIY: ATF Change
yeah genuine honda ATF, fluid level is good when i checked. i hope my tranny isn't going. does it take time for the ATF to settle before it works prooperly or does it work at once?
Old Feb 8, 2009
  #59
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Re: DIY: ATF Change
When it's fully warmed up and running, and you've checked it, the fluid should be fine.
Old Feb 8, 2009
  #60
Re: DIY: ATF Change
yeah its fine when i checked. someone said it could be the throttle body need adjusting or the control sensor. what u think?
