retrofitting question
Old Dec 20, 2012
ericf1993's Avatar
ericf1993 is an unknown quantity at this point
i have a quick question with trs h1 kits. they offer both a complete kit for 270 and a smaller kit for 120. i was wondering for someone who has a 2003 civic stock headlights, and has no other hid equipment on hand, which one should i get?
Old Dec 20, 2012
Re: retrofitting question
easiest route would be to buy the Morimoto mini (either D2S or H1, doesn't really matter) retrofit kit. Those come with everything you need: projectors, bulbs, ballasts, relay harness, shrouds.
The smaller kit is just the bulbs and ballasts, and you'd end up being one of those guys on the road that blinds everyone and their half brother.
the difference between the D2S and the H1 kit is just the bulb. a D2S bulb is a true HID bulb, whereas the H1 HID bulb is just a rebased bulb.. You can get better quality bulbs with the D2S kit, but H1 bulbs will typically be cheaper.
Old Dec 20, 2012
ericf1993's Avatar
ok thanks! i will look into the complete kits. how would i go about aiming them the correct way? can i aim them while they are on the car? or would i have to take the lights off the car to aim them?
Old Dec 21, 2012
GolNat's Avatar
Prelude Owner
You can aim them using the stock adjuster screws since your putting them in your OEM headlights. I was able to aim mine perfectly with the stock adjusters. So you can put the projectors in and seal the headlights and mount everything, and adjust them after everything is put back together.
Old Dec 21, 2012
rjones7755's Avatar
Yeah you can aim up/down, but before you seal them back up you need to make sure the projector's beam's are completely horizontal to the ground so you have a beam pattern like this -- not this v
Old Dec 21, 2012
GolNat's Avatar
Prelude Owner
Don't the lock rings and washer adapter thing keep everything horizontal? I couldn't rotate mine to not make it be horizontal.
Old Dec 21, 2012
ericf1993's Avatar
is it possible to make sure if theyre horizontal or not without turning them on?
Old Dec 22, 2012
rjones7755's Avatar
@golnat what year is your civic?
@eric I put the HID's in and turned them on and adjusted accordingly i dont think theres a way to do it without em and be totally sure lol
Old Dec 22, 2012
GolNat's Avatar
Prelude Owner
Good point! I have an 01 which is a h4/9003 style.
Old Dec 22, 2012
rjones7755's Avatar
Yeah there is no adapter plate for the 9006 unfourtunatley or i would've save a lot of time lol
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
