Window Trim Flaking?
Old Oct 25, 2011
TedT100's Avatar
CurbStomp
TedT100 is an unknown quantity at this point
Question Window Trim Flaking?
Bought this car, noticed the window trim paint was flaking off, I pulled a bunch of it off and it appears to be stainless steel underneath, should I just pull the rest of it off? It gets hard to pull off at the edges any recommendations?
Thanks
Old Oct 25, 2011
lazlong's Avatar
Re: Window Trim Flaking?
It's steel but, not stainless. That piece just pops off. Paint it or get a new one.
Good parts source: http://www.hondapartscheap.com/index.php?p=home
Old Oct 30, 2011
TedT100's Avatar
CurbStomp
any tips on how to pop it off?
Old Oct 30, 2011
lazlong's Avatar
Go get a trim tool or wrap your smallest flathead with tape and starting at the front CAREFULLY pry the strip up. Replace any broken clips.
Old Oct 31, 2011
TedT100's Avatar
CurbStomp
Alrite thanks man
Old Jun 4, 2012
sjryser's Avatar
sjryser is an unknown quantity at this point
what is the part called?
Old Jun 4, 2012
sjryser's Avatar
nm found it...http://www.hondapartscheap.com/produ...s5p-a00-honda/
Old Jun 5, 2012
si985's Avatar
si985 is an unknown quantity at this point
where can u find the clips
Old Feb 19, 2013
Slowe1978's Avatar
Slowe1978 is an unknown quantity at this point
Does anyone know how to install this part? Old ones broke off, got new ones but don't know exactly how to install them properly.
Old Feb 19, 2013
BlueEM2's Avatar
Whachya lookin at?
They just pop in do they not?
Old Apr 18, 2014
Ghettochild2600's Avatar
Ghettochild2600 is an unknown quantity at this point
Hi, to remove them get a flat head screwdriver and lift up on the trip a bit. You should see 5 clips holding it on. Just push in and it will pop out. As for the flaking what I did with mine is take a grinder or DA sander with 80 grit and smoothed it down. Then sanded with 180 grit and painted over them with gloss black. I didn't like how the gloss black looked so I scuffed them up giving the trim a more natural look. I was very pleased with the end results. I'll post a pic later.
Old Feb 28, 2016
malcolmgrey's Avatar
malcolmgrey is an unknown quantity at this point
I read the tips, popped off the two rear ones (strangely the front doors are OK) used the wire wheel on my bench grinder to carefully brush off the old black coating (take care not to brush the rubber edges), be patient and very careful)I sprayed two coats of primer and two coats of semi-gloss black from aerosol spray cans, and they look as good as new.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
