Aftermarket Stereo Removal
Rep Power: 0 Aftermarket Stereo Removal
I have a jvc deck in the vehicle that was installed before i purchased the car; is there a way to take it out without going through the process that you would if it was a stock headunit? Does the single deck with the cutaway just pop out or do i have to remove the whole dash?
Received 1,148 Likes
Rep Power: 485 Re: Aftermarket Stereo Removal
If its installed properly, no. Head unit is screwed onto the head unit bracket, which is bolted down behind the panel with the cigarette lighter adapter
