New lady from Gaston County, NC
Old Feb 23, 2010
LauraAshley1989's Avatar
LauraAshley1989 is an unknown quantity at this point
Hey y'all!
I'm Laura from Bessemer City, NC. I have had my civic less than a year! Its a 99 civic lx. The reason I'm on this site, is because I can't find out whats wrong with it! I went and filled up the tank on my way to work, drove fine and everything, that next morning, I woke up, was heading out, and now it won't crank! My machanic has checked the fuel pump, but its working. He also changed the main relay, it still doesn't work! What could this be? It's turning over, just won't crank! The fuel pump doesn't engage. We took the fuel pump to a battery, and its turning. Is there anything else we can try or do that could get it to crank? Please help me!!! Thanks!
Old Feb 25, 2010
02civicsi02's Avatar
Low and slow!
Re: New lady from Gaston County, NC
Welcome first off. I am from NC to but anyway if the fuel pump is working the your fuel line could be clogged, if not that is your car getting spark at all. There are so many things that could be wrong. Is this all that you have checked.
Old Feb 26, 2010
Well, he is now checking the wiring! I will tell him about the fuel line! He can check that too!!!
Its nice to meet you! You're not too far!
Old Feb 26, 2010
Low and slow!
I pretty far away but not to bad. I live in Marion its like 30 mins away from hickory. Another problem could be your distributor, the cap could be wet or you just need a new one. Also if your fuel line is good then the next step could be the injectors. Its kinda hard to tell you whats wrong when I am not there to look at it. One of the main problems with fuel lines in the winter time is the fact of the winter gas blend, just make sure when you get her running put some injector cleaner in the gas tank to clean the lines out alittle.
wingsfan19
15
Sep 2, 2015 02:15 AM
sccarally
Texas
Aug 21, 2015 10:09 PM
m.colley
Jul 20, 2015 04:48 AM
sccarally
Texas
Jul 3, 2015 04:43 PM
vtecbrah
May 31, 2015 01:24 PM
