Turn signals light up with headlights
Old Nov 22, 2016
JediMasterMax15's Avatar
JediMasterMax15 is an unknown quantity at this point
Hi all,
I just replaced the headlights in my wife's civic. When testing them, I noticed that the turn signals are lit up whenever the headlights are on (both sides). They still blink if used.
1) Is this normal behavior for a 2004 Civic?
2) If not, this is probably a crossed wire somewhere? Any tips on where I could look for that?
Any ideas will be helpful. Thank you.
Old Nov 22, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Turn signals light up with headlights
I believe this is normal. The bulb used for the turn signal and parking light is a dual filament bulb.
Old Nov 22, 2016
Thank you!
Old Nov 22, 2016
The park light is lit up, not turn signal. Turn signal is much brighter than a park light.
Same bulb, two filaments, two brightnesses.
Old Nov 23, 2016
Carbuff2's Avatar
Honda Maniac!
Carbuff2 is an unknown quantity at this point
Poor grounds could cause such an issue. 'Lectricity always seeks a path to ground...even if it is through another light filament.
