Retrofit flickers when I hit a pothole... help!
Old Oct 25, 2007
gbs-one's Avatar
gbs-one is on a distinguished road
My retrofit starts flickering when i hit a small bump on the road usually on the freeway. Then it would start going back to normal when the road is clear and even. This problem started when I lowered my car an inch and a half. My suspension set-up is very bouncy so I'm thinking that might be the problem. Also, I put the ballasts on the headlight support. That may also play a small role in this problem.
Has anyone encountered this issue??? Please help.
Old Oct 25, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
Re: Retrofit flickers when I hit a pothole... help!
im pretty sure that its just a connection problem. OEM hardware should be sturdy enough to handle the bounces and bumps. Look over ur connections again and make sure everything is secure
Old Oct 25, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
^ Yea what he said....my retro does not have your problems...I also put ballast behind headlights....wires loose in your case...its really bad for your ballast...
robjcivic
Mar 12, 2017 12:10 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
