Hi, I've done a search but have not come across anything in this regards, but my mate has asked me to look into upgrading his current 'normal' to the projector lights like on the Type R and all later 7th gen Civics.
Problems so far are that obviously some light fittings (such as the direction indicator and parking light) are different. This isn't really a problem as such but as we want to use the existing wiring (no body wants to sell the loom / want TOO much for it) has anyone got a wiring diagram that could help? On the original lamp, there is I believe a H4 bulb fitted which uses the same plug for the high beam, but as the high beam light is seperate on the Projector lights, where do I feed this from?
Obviously I can work this out but would appreciate it if anyone has already done this to verify which wire is what?.
Thanks in anticipation.
