Retrofit question
Old Oct 27, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
Retrofit question
where can i buy just the projector housing i have an H4 bi/beam hid kit already hooked up and now i would like to get a set of projectors to fine tune it if that can be done?
Old Oct 28, 2006
hwt101's Avatar
anbody?
Old Oct 28, 2006
your h4 kit wont work with any projector. oem hid projector all use d2s oem bulbs from philips or osram. if you are doing retrofit with hid projectors, you also need to get new ballast/bulbs for them. and just sell your kit.
Old Oct 28, 2006
hwt101's Avatar
im looking for somethign like a tyc projector to use my h4 bulbs w/ that i could retro fit into my stock head lamp
Old Oct 29, 2006
um you cant use halogen projectors with hid. and the tyc is H1 too. hid bulb in tyc halogen = crap. it will be worse than your oem setup. spend the extra money, get a real hid projector and new bulbs and ballasts. check ebay, check hidplanet.com. i decided on the audi a4 valeo projectors. not disappointed at all. i got the projectors/ballast/bulb for around $400 which is on the expensive side. you can find them cheaper. the whole retro cost me almost $800 but i messed up, and there were extra expenses like buying new headlights and stuff. but you could get all the hardware you need for around $300-$400 depending on how long you shop around.
Old Oct 30, 2006
LiKEaFeRiO's Avatar
TYC projectors
NOT HID.
They use H3 HALOGEN bulbs.
TYC makes the entire housing to replace your stock ones.
You will need to buy H3 sized HID bulbs + mod them to fit.
HID projectors
Real HIDs
They use D2S HID bulbs.
Usually removed from other housings to be retrofitted into your housings.
You will need HID projectors, housings to retrofit them into, d2s bulbs, your current ballasts, AMP to D2S adapter from eBay, patience, time, and creativity.
visit hidplanet.com if you are confused about what HIDs or retrofits are.
Old Oct 30, 2006
dirtySAMURAI's Avatar
I log in from time to time
tyc uses h1, buddy
Old Oct 30, 2006
LiKEaFeRiO's Avatar
Opps H1 thanks for the correction
Old Oct 31, 2006
jay78's Avatar
jay78 is on a distinguished road
yes do what he said....sell your kit buy some oem hid kit and extra set of headlight....
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
