Stupid LED problem
Old Sep 3, 2006
jer2k's Avatar
jer2k is an unknown quantity at this point
Stupid LED problem
OK so i have the most retarded things happen that never have solutions but here in another one in case anyone knows.
I have LEDs installed in my my A/C vents so they glow at night. They all worked splendid for about 2 or 3 months. They are supposed to come on when I turn the lights on. Then the other day i took out my indiglo gauges cause they stopped working. Now they just flash on and off quickly (and stay off) when i turn the lights on. The guages were grounded to the same ground as the vent LEDs and now the vent LED dont work. ALso on the same ground as the LED's is my Kicker digital remote controller (which works) and my Alarm LED( still works)
The vent LED are powered by the light in the automatic shifter. That lights still works as well.
Old Sep 3, 2006
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
I don't see how that could happen if you wired it all that way, but who did the wiring? I would say pull an led and resistor out and try it alone, if it is good follow your wiring, and what kind of alarm do you have that grounds the led in a seperate location?
Old Sep 3, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
if gearbox has time to answer, i would pm him. he is the electronics god
Old Sep 6, 2006
its either bad resistor job, or something with dimmer. the auto shift light is connected to the gauge cluster dimmer. so if you dim it too much there will not be enough power to keep them on, if they were resistored for 14.4v hopefully.
Old Sep 10, 2006
SloW4Sh0wVic's Avatar
SloW4Sh0wVic will become famous soon enoughSloW4Sh0wVic will become famous soon enough
i would never keep leds in the vent
ive noticed condensation flying out of the damn things, haha!
MamaBear2015
May 27, 2015 12:04 PM
eorlando1
May 17, 2015 11:16 AM
ImmortalEX
Jan 2, 2002 08:45 AM
blackbullet
Dec 1, 2001 03:44 PM
DaPipeLayer
Nov 14, 2001 08:06 AM
