tail lights
It's a physical fit, but you have to do some minor rewiring. Here's the procedure to do said rewiring:
http://www.7thgencivic.com/forums/sh...d.php?t=158488
Yeah, A lot of things can be found if you're careful about the terms that you use to search. But it's not a problem man. If you can't find the answer after searching your eyeballs out, then post and usually the non-******* members will try to help you out.
Hoagey
Lighting
Jun 13, 2015 01:07 PM
shaejb15
Apr 12, 2015 11:38 AM
