Hid Question
Old May 25, 2006
topsecretjapan's Avatar
topsecretjapan is an unknown quantity at this point
Hid Question
If I buy a McCulloch HID kit and say I blow a bulb. Can I use any HID bulb or does it have to be there bulbs? Just curious in case I would want to upgrade bulbs. Which Kelvin rating should i got with? 5K-8k?
Old May 25, 2006
dirtySAMURAI's Avatar
I log in from time to time
if you buy mcculloch, you've bought into their system. you cannot use OEM bulbs with a mcculloch kit. as far as what color you should get, you should stick to OE spec - 4100-4300k.
Old May 25, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
I totally agree. BTW it's always better to use oem gear instead of a kit.
Old May 25, 2006
are they a good brand to go with? im not looking to replace the bulbs with OEM, Im just saying if I have a MCculloch kit and I would decide to use Ignited or Philips HID bulbs in there would it be possible?
Old May 26, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
Pretty much all of the bulbs that comes with a kit is rebased and you are pretty much stuck with that type of bulbs, which turns out to be very @#$% bulbs.
To gain the advantage of HID you should do a retrofit and use OEM Philips/Osram bulbs, not kits...
Old May 27, 2006
jay78's Avatar
jay78 is on a distinguished road
so u got mccullach installed on oem headlight ?
if yes
then u can use d2s oem bulb
with H4 bulb housing you need to buy this two things
http://cgi.ebay.com/ebaymotors/H4-90...QQcmdZViewItem
and this
http://cgi.ebay.com/ebaymotors/D2S-D...QQcmdZViewItem
3rd will be d2s 4300K bulb
Old Jun 15, 2006
03whitecivic's Avatar
03whitecivic is an unknown quantity at this point
if yes
and this
that is he wants to use a different bulb right?
Old Jun 15, 2006
jay78's Avatar
that is only if you wants to use oem bulb(different bulb) cuz they dot blowup like after market one does...
Old Jun 17, 2006
LiKEaFeRiO's Avatar
if yes
and this
Bingo!
HID bulbs run on 2 wires; a positive and a negative.
If you can clip, strip, and solder you can make almost any bulb/ballast work together.
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
