no lights?
Old May 20, 2006
fluk3d's Avatar
fluk3d is on a distinguished road
no lights?
well i'm driving from work.. and suddenly all the lights on my cluster go off.. so im like ok, i'll try turning car off and on. didngt work. So I get out of the car, and my fog lights don't turn on, and I have no lighting going to the tail lights. the only lighting is to the headlights. Any ideas what can be causing this, maybe battery is starting to die out?
Old May 20, 2006
dead battery? does the car start? if so it might be a bigger problem like fuse or wiring.
Old May 21, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
May be the ICU (not ECU)...that's behind the fuse box...
Old May 21, 2006
fluk3d's Avatar
yeah car starts no problem. So I started looking around in the fuse box today checking out the fuses, and found one of the fuses blown (small light 15) replaced it with a spare, and everything worked. I'm wondering what made that fuse blow, they don't usually just blow.
Old May 21, 2006
do you have any stereo stuff other than stock?
Old May 21, 2006
fluk3d's Avatar
yeah aftermarket jvc headunit. I have a feeling its my oem fog lights. I wired them to my night lights so every time i turn my lights on the fogs come on. I did that because the switch I got didn't fit.
Old May 21, 2006
yea bad idea hooking 55w bulbs to wires only designed to power 5 or 20w bulbs. you need to hook up a relay so the parking light triggers the relay to then get power to the fogs from a larger power wire run from the battery.
Old May 21, 2006
fluk3d's Avatar
yeah i'm thinking im just gonna go get a oem fog light switch from honda and rewire it.
Old May 22, 2006
fluk3d's Avatar
well fuse went out again, so im guessing there is a short. Just gonna rewire the whole thing again with a switch this time.. hopefully that's what causing the problem.
Old Jun 2, 2006
eyegiant's Avatar
eyegiant is an unknown quantity at this point
I am having the same problem with mine. what would I need to do to disconnect all wires that power the fog lights?
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
