Aiming lights outside of car for 04-05 ?
Old Mar 5, 2006
herroherror's Avatar
herroherror is an unknown quantity at this point
Does anyone know if you could aim 04-05 headlights outside of the car by placing it on a flat level surface?
Would the way the headlights are sitting on a flat level surface be the same as the headlights sitting on the car? Or would they be angled differently?
Old Mar 5, 2006
hdave's Avatar
hdave is an unknown quantity at this point
u gotta aim them while they are on the car
basically if you take them off and put them back on your most liukely going to need to aim them again as it will be off a little bit
Old Mar 5, 2006
RHCP0801's Avatar
how would you aim them anyway?????? there would be no power to them
Old Mar 5, 2006
Let's say you could power them off the car... if you had a perfect horizontal line while the headlights are mounted to the car, and u took them off and put them a surface parallel to the floor instead and shined it on the same wall, would there still be a perfect horizontal line?
just wondering so I could figure out if i could aim hid projectors in them without them being installed on the car.
In that pic, there are little pegs on the bottom that make them sit they way they do on a horizonal surface. I'm not sure if they're mounting points or not. But maybe they're there so you can aim the lights without them being on the car?
Old Mar 6, 2006
ragingSPAM's Avatar
I just burnt my tongue
you have to have them on the car and there are adjustment screws on the backside...get a philips screwdrivers and you will see a little knotch...turn the screwdriver right to make it point higher and left for lower
Old Mar 6, 2006
TemjinX2's Avatar
if your doing a retrofit you want to align them when there on the car. The most important alignment is the rotational. If your rotation alignment is off your beam pattern won't be that wide. Everything else is relatively easy to fit. But trust me, you wanna aim them with them on the car.
Old Mar 7, 2006
Are you sure that's the only way to get a proper alignment? I'm just worried about rotational alignment because I don't want to drill extra holes if it turns out crooked.
Is there a way to get perfect rotational alignment by looking at the oem reflector? In that pic, there are two horizontal lines on the reflector... did you find that with your retrofit, your projector shield lined up with those lines?
Old Mar 8, 2006
TemjinX2's Avatar
you can try using the lines, but you want to mount them on the car before you finalize it. On my e46 projectors i tried to make the opening of the projector as flush with the back stock opening where the stock bulbs plugs in. I also used the dot line on the lense of the e46 to give me an idea on the rotational.
I mounted it on my car and made minor adjustments to try to correct the rotational. Its still a little off though.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
ImmortalEX
Jan 26, 2002 05:55 PM
AZ2K1Civic
Oct 27, 2001 10:24 PM
