My retrofit project Done with cutoff
my retrofit project almost done......just got to reseal it..
two retrofit....i did valeo d2s in to tyc ECE shield.......and other one i bought it from this site.......valeo h7 in to tyc DOT shiled. ......i should hve my valeo d2s on my car over the weekend......
here some pic...
this pics are from
Valeo D2S ECE shiled and clear lens....l bend the shield little bit for more colors..
let me know wat u guys think
here some pic...
this pics are from
thankx infi for all the help during my project...aslo thankx mikenam too.
and yes i will post wall pics...when its done....hopefully this weekend...
looks nice and clean. the aiming is good too. 7th cuttoff pics looks kinda off. but w/ the tyc u cant really rotate unless u make an adaptor. the other cuttoff pics look well aimed. got some nice color from those clear valeos.
just make the valeo screw hole litt bigger then put screw thru then two screw nut behind and front
here is the pic
here is the pic
just set up your oven to 200 , then put your head light in for 10 minutes then open do the same thing for 2nd light............
do same thing to put it together..
arn't u glad u did the retro yourself. it wasn't that hard right? The hardest thing was probably aiming the projectors.
what are u doing w/ the other set of headlights? Thats a lot of silicone used to hold the h7 projectors.
thats right dude....aiming projectors was pain in the ***....and they still not 100% aimed......my driver side need lit work needs to roted counter clockwise.....i just gone keep it as it...cuz thats toomuch work..
what are u doing w/ the other set of headlights? Thats a lot of silicone used to hold the h7 projectors. i know their is lots of silicone....that i bought it from this site....thats my backup pair.....
A big, hairy Kentucky boy
I too am going to do a retrofit soon. This is what I have to work with as of right now:
and it's beam patter(on my ceiling):
Everything came out of a headlamp for a 2004 Nissan Maxima. I've only got one right now, but I have a second on the way.
Originally Posted by jay78
good stinkypie...are u gone put this in to oem housing....or aftermarket ???
and what type of projectors are those.....d2s ??h7??
The projectors I'm not sure about, they're the ones used in an 04 maxima.
Originally Posted by stinkypie
If I can't get it to work in an aftermarkey housing, I will retro into an oem and replace them with aftermarket during the fit.
e55 bi-xenons. good choice, but not the best in bi-xenons (TLs, afaik). good to know people are actually doing retrofits now, though, instead of wasting their money on kits.
I now work in Toyota parts, but one of my friends took my old job.
I work with what I can. Being that I worked in a Nissan parts department, it isn't surprising I got ahold of this for absolutely nothing(no, I didn't steal, people have problems with the headlamps being properly sealed in maximas). Everything tests out good. I just have to get some cash to get new housings so I can get to work.
infi.....i aimed my headlight house higher....so light is more brighter....and more colors....but cant line up cutoff.........i hve valeo h7 with d2s adpator i will try that fore couple days see how that looks.....
ricer_em2
May 11, 2016 08:09 PM
Touge
Sep 22, 2015 11:55 PM
Touge
Ottawa
Sep 22, 2015 11:52 PM
Touge
np glad to help a fellow 7thgen.
