How to mount projectors?
Well, I got both the reflectors out, and now I'm slowly cutting away at them. I'm having problems coming up with ideas to mount the projector. Does anyone have any? Im probably going to use 4 screws and then instead of setting the projector on the floor of the reflector it will sit on where the bulb shield comes out. It will use that mount as a shelf which will help it hold steady and vibrate less. After the 4 screws are on....do I need to use anything to keep the projector to the reflector? I need rotational aiming too...how would u guys go about that?
use some nuts to keep the projector from wiggling [too] loose. as for rotational aiming, i havent figured anything out that would be as easy to use as larry's (littodevil) single screw, +/- 30 degree thing.
4 screws will keep the projector in the headlight very securely. i have my ZKWs mounted on 2 screws and they dont wiggle/vibrate at all
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
