How do you wire.......
Old Apr 13, 2005
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
Talking How do you wire.......
how do you wire neons that will go under the front seats??? i have already done a search and could not find anything. i just want to get a couple of neon bars and wire them to a switch to be placed next to my power adapter. any thought, feelings or emotions?!?! thanks
Old May 16, 2005
Diver's Avatar
Diver is on a distinguished road
bump
Old May 16, 2005
dirtySAMURAI's Avatar
I log in from time to time
wow. seriously?
+ is positive (usually red wire)
- is negative/ground (usually black wire)
tap the + wire to one plug for the switch, tap the other + wire to the cigarette lighter + wire, then ground the black wire to your chassis. mount the neons wherever...
Old May 16, 2005
shmik1's Avatar
you can tap into a fuse if u want it to be hidden, neons dont take much juice
Old Jul 6, 2005
chicohonda02's Avatar
Since 2002 Baby!
i put mine to switches.
Old Jul 6, 2005
MegaHurtz's Avatar
put the switch on the ground that way you run a continuous live power line to the neons that won't come disconnected anywhere else and short out... if the ground comes off and shorts out... oh well the lights turn on big deal
put a fuse on the power line anyway, just because it's good to. .5 amps per tube should suffice
Old Jul 7, 2005
gh0st's Avatar
TAQUITOS!!!!
how exactly do you tap the fuse? just like you tap any other wire?
Old Jul 7, 2005
MegaHurtz's Avatar
^^ yeppers
