HID question
Old Feb 20, 2005
EssEss21's Avatar
EssEss21 is an unknown quantity at this point
HID question
Alright guys, ive got Black housing projectors and i wanna get some HIDs, ive heard that you shouldnt put HIDs in the plastic black housing projectors because it'll get very hot, so is this true? if i want HIDs is the only way to use my stock headlights? thanks for all the help.
-ryan
Old Feb 20, 2005
TemjinX2's Avatar
i think it should be ok. Its best if you ask gearbox or impluse this question. HID's use less wattage then halogens and i think they give off less heat then halogens. So they should be ok to use. Most people recommend you dont use those kind of projects for HIDS because the projectors weren't designed to use HIDS. Its best if you want to get that bimmer look to do a retrofit. If you just want brighter lights then your stock housing would probably be better.
Old Feb 20, 2005
skipbarber's Avatar
thats about right. HID's run cooler than halogens because they are more efficient. Halogens are less than 10% effecient if you compare the amount of heat they emit compared to the light they output. You can put H1 HID's into your projectors, but you wont be too happy. If you want to keep projectors you should do a retrofit with HID lenses and their respective bulbs, ie DS2. I have HID's in my stock headlights, and am about to put some in my gf's 7thgen too. IMO, for the money, stock headlights w/HID's give you the most bang for the buck.
Old Feb 20, 2005
dirtySAMURAI's Avatar
I log in from time to time
where are you getting your information? hids run at about 450*F at the hottest point, but it doesn't spread the heat the same way that halogen does. so, i guess in theory it is cooler than halogen, but literally it is waaaaaay hotter.
do a retrofit
Old Feb 20, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
moved to Lighting subforum.
Injen
Old Feb 20, 2005
ImPulse's Avatar
-ryan
Since you are have projectors, the housing doesnt matter cause the bulb is behind a projector/lense. You can get an aftermarket kit for OEM housing or Aftermarket Projectors.
Although, You can also go the retrofit route.
http://www.7thgencivic.com/forums/sh...d.php?t=194211
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
