OEM foglights
Old Jan 9, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
OEM foglights
not sure where to post this but i guess here will do...
I am wanting some foglights and found some for a good price!!!
http://www.robearracing.com/pd_honda..._01_up_oem.cfm
My question is...
I have already cut out the slots where the oem fogs go.... i was wondering if that is gonna cause a problem with installation? I cut them out to give more airflow to my intake... But i only cut out the certain spot for the foglight...
that pic is the best i can get of what i am talking about...
Basically just wondering if that would cause a problem if i get oem fogs
injen
Old Jan 9, 2005
I don't understand? The oem fogs come with a cover that goes over that black bart and curves inward where the grill is. You will prolly need to cut more actually to make them fit.
Old Jan 9, 2005
injencivic's Avatar
i am just wondering if the cutting that i did will cause any problems with the install of the oem fogs?
Old Jan 9, 2005
No probs
Old Jan 9, 2005
dalaw's Avatar
Bone Stock!
go to www.handaaccessories.com they have a free installation guide on fog lights on PDF.
Old Jan 9, 2005
CivicSky's Avatar
CivicSky is an unknown quantity at this point
Yes, you may run into some mounting problem because you supposed to leave a 2x1 inch plastic at the cornor of both openings for the OEM fog to hold in place. I can send you some pics when I get home.
Old Jan 9, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Jan 10, 2005
_Viper_'s Avatar
Hey guys can you please post the Adobe instruction or a link to them please..
I have 2005 Fogs and a crappy instruction booklet
thanks
Old Jan 11, 2005
CivicSky's Avatar
Make sure you keep that little 2x1 inch thing at the cornor on each side.
Old Jan 11, 2005
ImPulse's Avatar
^ wow, you cut that nicley...
Yea, You need too enlarge the hole more so that they will fit.
UltraHDGames
Jun 8, 2016 05:16 PM
thatcham
Sep 30, 2015 08:28 AM
Cam Diaz
Sep 28, 2015 08:34 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
h4ldol
Sep 10, 2015 12:25 PM
