$350 just to retrofit?!
Old Jan 5, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Damn! i was looking at hidplanet.com and they have a retrofit service that you can send in your headlight assembly and for $350 (plus return shipping) they will put in HIDs (which btw you have to buy before hand)
so GD! thats a lot for lighting if you were to do it that way i assume around $600 - $650?
Old Jan 5, 2005
ImPulse's Avatar
yea... retrofit is expensive, i charge 200$
but yea, expect too pay a lot
Old Jan 5, 2005
taz757's Avatar
I might have to get a set of TYCs and send them off to you. Do you also provide all the hardware necessary? Ballasts, bulbs, lenses? How would we go about aligning them once they're on the car?
Old Jan 5, 2005
ImPulse's Avatar
I can get you all the hardware/hid equiptment you need... I can align them on my car and send em out too you (since we have the same car).
Old Jan 5, 2005
ya - so say if we sent you a set of TYC's what would the cost be for the actual HID kit and then retrofitted in the headlight assemblies and then shipped back. a ball park figure would be ok
Old Jan 5, 2005
ImPulse's Avatar
Since tycs are soo small, I really suggest either Valeo a4 (single beam only) or TSX projectors...
Valeo projectors are on ebay a lot... Most go for around $130-180 (H7/Halogen) but, they work well with HIDs..
OR
you can get the real HID/Xenon Valeo projectors for around $250
Shipping is usually like $20 ups/usps ground...
So, If you are providing the TYCs/Headlamps > 400$ roughly?
Old Jan 5, 2005
OR
you mean you can get the headlight assemblies with hid already in them!? plug 'n play kinda thing??! cuz if ya, FocK! im pissed haha
Old Jan 5, 2005
ImPulse's Avatar
no... just the projectors
Old Jan 5, 2005
ah fock it i'll just come out and ask. and i know and i know you guys flamed some noob for asking "what are HID's" in a thread a couple weeks back. but i just want some stuff cleared up. so here goes...
the assemblies are the part you can paint right?
and the projectors are the things with the lens on them that you put in the assemblies? right?
and then the HIDs are what you put behind the lens on the projectors ?
am i right? or way off?
Old Jan 5, 2005
dirtySAMURAI's Avatar
I log in from time to time
2. and the projectors are the things with the lens on them that you put in the assemblies? right?
correct. here is a picture of the tyc projector out of the "headlight assembly" (i just call it a headlight..but whatever floats your boat).
3. and then the HIDs are what you put behind the lens on the projectors ?
sort of...
HID bulbs go inside the projector assembly. the rest of the HID kit should be installed elsewhere (it won't fit inside the projector....)
inside this hole (e46 xenon projector) behind the metal shield
Old Jan 5, 2005
alright alright - i think im catching on. learn somethin new everyday, eh? lol
so you said the rest of the kit goes elsewhere. what does the rest of the kit include and where does it go?
Old Jan 5, 2005
rest of kit would be wiring [harness], ballasts, ignitors (if they're separate from the ballasts)...and i think that's all? you may use a relay so that your HIDs dont go out when you use the high beams, but thats complicated..
Old Jan 12, 2005
ser02rav4's Avatar
ser02rav4 is an unknown quantity at this point
who can give less than 200? sorry impulse, just kiddin
Old Jan 12, 2005
wait wait - i don't know that term yet. haha - whats a ballast???
Old Jan 12, 2005
gh0st's Avatar
TAQUITOS!!!!
ballast is what sends power to the bulbs while they're on. ignitors spark the bulb to get them lighted and the ballast keeps them on
Old Jan 13, 2005
ahhhh i see. haha
alright since we're going with this - lets talk about the actual retrofit? what is involved in that? my thinking - having no background info, just a guess - is that you basically "make" the HID bulb fit into the projector right? shaing the sides or somehow making the opening bigger - then fitting the hid bulb and sealing it in? i dunno
Old Jan 13, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
www.hidforum.com you can learn to do your own! you just gotta be crafty!
Old Jan 13, 2005
you should buy a nice projector that will require little modification to fit. i found the best projector to use with TYCs is the valeo h7/d2s projectors out of an audi a4. they have a very nice cutoff, nice output, and the aiming bolts for the TYCs just need to be bent inward a little bit to fit the valeos.
Old Jan 20, 2005
cecknight's Avatar
cecknight is an unknown quantity at this point
will the valeo's fit in the TYC projector slots?
Old Jan 20, 2005
ImPulse's Avatar
no, the valeos are a little bigger
Old Jan 20, 2005
my valeos are smaller...
edit: or are they?
Brad Andrew
Sep 8, 2015 08:25 PM
cyc
Jul 22, 2015 01:14 PM
