what is needed for retrofit?
Old Nov 8, 2004
mikenam's Avatar
mikenam is an unknown quantity at this point
i want to retrofit either the valeo's or the s2000 projectors into my stock headlights.
itll prolly be a long time later till i do the project (money, time, money)
before i do it i want to research what parts i need to make the install easier and not waste $500+.
1) The 7th gen civic comes equiped w/ H4 head light bulbs which incorporate hi/low beams into one bulb. does that mean if i were to get HIDs i would i have to get BI xenons or would i be fine w/o it?
2) there is this one site HIDtech.com which sells a HID package which consist of
2 Valeo ECE spec H7 projector (with H7 adapter).
2 Hella generation III ballasts.
2 Philips 85122 D2S HID bulbs (4300K).
is that all i need to finish the setup? They say it comes w/ H7 adapter
would i need a H4 adapter?
3) would i need to buy a protective enclosure and shroud?
4) would i need to buy some sort of harness?
5) has anybody in this forum done the retrofit? was it hard to do w/ the 7th gen?
6) and the last question is............can some one write up a DIYrojector retrofits. to anybody that does .
thank everyone.
Old Nov 9, 2004
Mr.Modify's Avatar
PM Impulse he should be able to help you out.
Old Nov 9, 2004
R1Style's Avatar
wait let me get this straight... you're going to be putting a Projector enclosure on your OEM lights? Why would you do that and how?
Why not just buy a HID kit made specifically for the H4's?
Old Nov 9, 2004
mikenam's Avatar
from what ive read, w/o the projectors HID lighting won't light up the road correctly.
Old Nov 9, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
wtf??? Where did you read that??? Take a look at any members car with HID installed, its hella bright.
Old Nov 9, 2004
tonyt915's Avatar
tonyt915 can only hope to improve
yeah the older tl's didnt have projectors and they wher hella bright, correct me if im wrong
Old Nov 9, 2004
ImPulse's Avatar
There is a big difference between an HID kit and OEM quality HID
With a retrofit there is,
Hardly any glare
Sharp Cut - off
Flicker/Twinkle of Colors
More focused light
OEM = Easy to replace bulbs (and not that expensive)
Downside to putting a projector in OEM housing....
Looks ODD (random thing sitting inside)
I would suggest getting a Bi-Xenon projector (so that you can have low & high beam)
If you have some questions PM me and ask, There are a lot of ways to get HIDs for your car
Old Nov 9, 2004
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Nov 13, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
Just got my HID kit from impulse, H4 plugged em right into my stock housing. look great. excellent beam pattern and very minimal glare.
if your looking to retro
you need a set of projector head lights (TYC)
a lense
and H1 HID bulbs.
get the H4 you will be happy
Old Nov 14, 2004
Rufus's Avatar
I think that my lights are brighter now that I put my D2s bulbs from my Audi Projectors into my OEM housing. Better light output anyway. Yeah I sacrificed the cutoff line and colors but the car looks more luxurious and less ricer.
mattdoc
Mar 14, 2017 12:10 PM
Myredjonda
Apr 14, 2015 07:00 PM
jessepimpride
Nov 13, 2001 05:59 PM
