lighting problem
Old Aug 28, 2004
fly_viet_guy's Avatar
not so fly, yet slow and enjoying it
fly_viet_guy is an unknown quantity at this point
lighting problem
anyone kno if its possible to manually re-align headlights? one of mine is obviously pointing directly at the street signs and the other at the ground..well maybe not that extreme.
Old Aug 28, 2004
ImPulse's Avatar
you can either bring it to honda... or re-adjust them yourself ( Honestly dont remember if there are screws/bolts to turn on OEM housing but, if there are then thats how you would align them)
If its aftermarket projectors then, turn the screws/bolts
Old Aug 28, 2004
There is a huge diy on how to do this, but basically look for a small gear on the headlight and stick a screwdriver (star shape) to turn it. It will move up and down.
Old Aug 28, 2004
i can find this screw...after removing bumper? oh and i called the honda dealership, they replied with "we dont do that here or have heard of it." great eh?
Old Aug 28, 2004
No, just open the hood and look down...nm I'll just look for the thread...
http://www.7thgencivic.com/forums/sh...adlight+aiming
Here you go, and there are alot of huge pics. Hope you have fast internet. Here's the pic. You stick the screwdriver in the hole and down to where the gear is to turn it. You can see it all here
Old Aug 28, 2004
i love u, i mean thanks
Old Aug 28, 2004
dirtySAMURAI's Avatar
I log in from time to time
if it's a coupe it won't have the screw to adjust it side to side. only sedans come with that.
Old Aug 28, 2004
well nvm...my car doesnt even look like that oddly enough. i have oem headlamps btw. but i did find that the headlamp itself is physically handing lower than the other....or the other higher...whichever. any suggestions?
Old Aug 28, 2004
and it is a coupe
Old Aug 28, 2004
Try to loosen the screws on top holding the headlamp in place. Then you should be able to move it back to the right spot. If it doesn't move, you'll need to take off the bumper to get to the other two screws underneath to loosen the entire headlamp.
Old Aug 30, 2004
streetglower's Avatar
Well whoever you talked to on the phone must have been an idiot or new. All hondas adjust headlights. They do it when they replace a headlight, and they do it when some people have no idea how a car works. Or have no mechanical knowledge.
Old Sep 4, 2004
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
I just put in my aftermarket bulbs and had sorta the same problem...
I just stuck my hand in there and wiggled the bulb until it fit into place and aligned with the stock bulb.
Old Oct 4, 2004
lilravingmatt's Avatar
lilravingmatt has a little shameless behaviour in the past
hmm gotta try that my needs 2 be align too! one of my points 2 the ground while the other points straight but farther ahead...
CarStuff
Dec 6, 2020 12:52 PM
cruisers10
May 12, 2015 10:46 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
blackbullet
Dec 1, 2001 03:44 PM
