Removing tail lights from '02 Civic sedan
Old Jul 10, 2004
poptop's Avatar
poptop is an unknown quantity at this point
Unhappy Removing tail lights from '02 Civic sedan
Help, Daughter has bought some Altezza tail lights off e-bay, I am having one heck of a time removing the stock tail lights. Have removed the three nuts, 1 screw, and clear clip; the tail lights are loose but won't come out. Looks like some plastic tabs on the bottom of light are in a bracket under neath, however, deep 8 mm is too deep and regular is too shallow.
Know you guys have taken these off in your sleep so help an old guy make his daughter happy.
Poptop
'91 miata and luvin' it...
Old Jul 11, 2004
LiKEaFeRiO's Avatar
You have to remove your rear bumper in order to gain access to some bolts on the bottom of the outer lights.
Theres 2 bolts on the top covered by black plastic covers and around 4 black clips on the bottom of the bumper. After removing these you should be able to pull the bumper off.
Old Jul 16, 2004
DareDebil911's Avatar
DareDebil911 is an unknown quantity at this point
I just broke the plastic brackets at the bottom, cause they're pointless anyways, ur fine with the 3 screws.
vtec92
May 4, 2017 03:20 AM
aus10
Apr 13, 2015 09:26 PM
shaejb15
Apr 12, 2015 11:38 AM
reLaXedinca
Nov 2, 2001 06:44 PM
Crash2002
Oct 26, 2001 05:02 PM
