HID dont fit in Sonar projector housing...
Old Jun 4, 2004
o2civic's Avatar
o2civic is an unknown quantity at this point
No flames please.. I genuinely need advise or insight into this.
So i have the Sonar Matrix x2 whatever projectors. I recently purchased a set of 8000k H1 hid kit just to find out the bulb is a tad too thick to fit through the projectors rear opening.
What do I do?
Old Jun 4, 2004
dragoon's Avatar
take a small rotary grinder to it? carefully, of course
Old Jun 4, 2004
ImPulse's Avatar
http://hidforum.com/diy/h1.php
somethin like that?
Another reason to why aftermarket kits are.... well, crappy
Old Jun 4, 2004
o2civic's Avatar
Not necessarily that problem..
The opening in the projectors housing is like a vertical rectangular shape. The bulb, naturally is round. The round bulb is larger in diameter than the rectangular opening. Any ideas? I might try the grinder tool to open it up a bit more. Nobody has had this problem before?
Old Jun 4, 2004
ImPulse's Avatar
have to cut it open more so that the bulb can fit inside...
Old Jun 5, 2004
o2civic's Avatar
i guess i need to do that.. but no one else has run into this problem? theres no projector I can get that does not require the cutting and fits in the sonar housing? that sucks..
Old Jun 6, 2004
ImPulse's Avatar
sonar projectors take H3 bulbs (i think?) plz correct me if iam wrong...
TYC projectors take H1 bulbs... Honestly, I think you would run into this problem with both projectors.
Old Jun 7, 2004
o2civic's Avatar
sonar takes h1. I had to replace the bulbs two weeks ago.
Old Jun 7, 2004
ImPulse's Avatar
k, well did u cut it yet? lol
Old Jun 7, 2004
o2civic's Avatar
lol.. not yet man... its been raining cats and dogs out here..
Old Jun 7, 2004
Voiceofid's Avatar
End Bringer
yeah, i had h1 hid and i had to cut the metal
take the headlight apart and cut the hole, otherwise you are going to trap a lot of metal shavings inside the light, and even flacks that would reside on the projector, cause poor lighting
Old Jun 7, 2004
Rufus's Avatar
I just put different projectors in my Sonars altogether,
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
TheRiddicles
Sep 21, 2015 03:43 PM
rnaodm
Sep 21, 2015 12:42 PM
TheRiddicles
Sep 21, 2015 01:28 AM
