I have TYCs
Old Dec 12, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
I have TYCs
I have a couple questions about retrofitting OEM projectors...
1) Right now i have H4 HID that i used w/ my stock housings... can i use these same ballasts with D2S bulbs?
2) How do i get the high beams in the TYCs to work while connected to the HID? (I'm assuming I would seperate the highbeam wires from the H4 plug/socket and solder them together?
thanks
Old Dec 13, 2003
ImPulse's Avatar
VoiceOfId did the same thing that u want to do but, with Catz? ballasts
all i had to do was sodder 2 wires, so for me, when i turn hi-beams on low beam stays on too
Old Dec 13, 2003
Voiceofid's Avatar
End Bringer
all you have to do is ground the ballast to the chassis instead of using the ground from the headlights
pdxbiker
Jul 11, 2002 07:13 PM
Player1
Jul 8, 2002 11:49 PM
FlippedOut
Jun 19, 2002 12:16 AM
GuSTo
Jun 18, 2002 01:50 PM
marux
Feb 22, 2002 02:06 PM
