Clean and adjust rear brakes for 2005 Civic sedan?
Old 09-30-2008
nyyanks81's Avatar
nyyanks81 will become famous soon enoughnyyanks81 will become famous soon enough
I stopped by the dealer for an oil change and was recommended by the service advisor that the rear brakes need to be cleaned and adjusted. Does the 2005 Civic have self adjusting brakes? Is it essential to have the rear brakes cleaned and adjusted?
Old 09-30-2008
Re: Clean and adjust rear brakes for 2005 Civic sedan?
i had mine done for $50 at a shop. they just take it apart and lube the parking brake cable. only reason i did it was the cable squeaked every time i pulled it. there is nothing really to adjust if the brakes are still good. i have 40% left of the original drum and shoe, and im at 85k miles to give you an idea.
Old 09-30-2008
DDragon7's Avatar
Just take them apart, blow out the dust, make sure you dont inhale any and lube up the moving parts (not the pad).
Old 10-05-2008
qijian's Avatar
is any kind of lube ok? does it create any sort of noises if it needs to be lube? because when i brake, it squeels real loud and goes away after a few brakes...
Old 10-05-2008
well yeah get disc brake caliper lube (or just brake lube) they have in small packet at the auto store.
Old 10-23-2008
(SnOwBoArDeR | FoReVeR)
Civic_Racer9's Avatar
or just get rear disc brakes
Old 10-23-2008
kcari's Avatar
its okay if u hear noise when u first break in the morning? I think its just the rusts
Old 10-30-2008
chinaman516's Avatar
chinaman516 will become famous soon enough
It's brake dust. Take the drum off, spray it down with brake cleaner adjust the star adjuster and your done.
Old 11-05-2008
Prowlin' with a Purpose
WannaBFast's Avatar
the squeaking noise coming from the rear is cause the brake shoes have been constantly rubbing on the backing plate of the drums for probablly 60k miles, they usually ONLY squeak when you release the brake, just put some brake lube between the backing plate and shoes by prying the shoes up just a little, you can tell where to put the lube by where the rust is... after you cleaned out the brake dust
while youre in there turn the little star wheel a few clicks, about 4 or so swipes with a flat screw driver will work
Old 11-05-2008
i miss the squeak, it got lots of attention when i would repeatedly raise and lower the ebrake lol.
Old 11-05-2008
WannaBFast's Avatar
my gas pedal squeaks... sounds like a small BOV when i shift
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
vtec92
05-04-2017 03:20 AM
dano2005
04-14-2015 01:58 AM
aus10
04-13-2015 09:26 PM
Crash2002
10-26-2001 05:02 PM
Quick Reply: Clean and adjust rear brakes for 2005 Civic sedan?
