P1361 Code, Engine Runs with half the power
Rep Power: 0 P1361 Code, Engine Runs with half the power
I have a 2001 Honda Civic and about a week ago the car shut off and the engine light came on. I turned on the car and it performed at half the power as before. I waited for about 20 minutes and drove the car again and the car worked fine then the problem occurred again. I took it to the dealership and diagnosed it and the code that came up was P1361. The dealer told me i had to replace the cylinder heads but i am not sure if that is the problem. Should i replace the TDC Sensor first?
Re: P1361 Code, Engine Runs with half the power
here's what the obd II code for that code says
P1361 TDC Sensor Intermittent Interruption
I would reccomend it, as a single sensor is a lot cheaper than heads
Rep Power: 265 Re: P1361 Code, Engine Runs with half the power
i'll even say clean the plug and check the wiring harness before you replace the sensor. your dealer must be high.
Rep Power: 0 Re: P1361 Code, Engine Runs with half the power
BUMP! Just got this code yesterday and had to tow it to the dealer. Started her up this morning and code/check engine light was gone. Dealer said they couldn't do anything without the check engine light. Maybe it's a loose connection and I need to clean up the plug. Does anyone know where that is?
Thanks,
Lewis
Thanks,
Lewis
Rep Power: 787 Re: P1361 Code, Engine Runs with half the power
usually caused by bad connection at the plug for TDC sensor. but its hard to get to it.
Car works fine now. Have driven on freeway and check engine light does not come on anymore. Should I really be concerned about this? I don't want it to stall on me again and have to call a tow truck.
It's been almost 2 days and the car is fine with no CEL or stalling. It's so weird that the car was in limp mode and on its last breath one day and then the next it drives like a champ. I'm a so frustrated with this. To the people have have had code P1361: how did you resolve this problem??
Anyway, to answer your question if this fixed my problem I've only driven on the highway twice since it was replaced but so far so good. If I run into the same problem again, I will let you know. Best of luck!
Dave
Happened again yesterday while on the freeway. I just dropped it off at the dealership. Will update on diagnosis. Hopefully it is just simply replacing the TDC sensor and not the entire head.
Just got a diagnosis from Honda and found out that there is excessive camshaft play and the entire head needs to be replaced.... arghhhh. That's $3000 down the drain. I guess GearBox is not the only one having badluck! $#%!&#$%* I HATE 7TH GEN CIVICS WITH A PASSION!!! Trading this damn thing in this weekend!
ouch yeah thats the time either trade it in or try and find someone with a cheap head (usually sells for $150) and have it swapped on for around $500 labor. so technically under $1k it can be fixed. idk.
Dave
Dealership claims the camshaft play caused TDC Sensor interupption. There is a bulletin out there for this problem: http://honda.justanswer.com/uploads/...1907_civic.pdf
Sensors can go bad or have a loose connection which can cause the CEL to come up too, but my case was the camshaft play because they opened it up to examine.
I just traded in the Civic. I think 7th gen civics are not as good as previous generations, if you have to replace the head for $3000, I don't think it's worth it.
Although I now own a Scion tC, I still love this site and will continue to visit!
Thanks, but car was sold ages ago lol
I was tired & frustrated with the car and didn't really care to ask the service tech on what caused the damn excessive camshaft play to happen. The 3 grand to fix this ultimately made me decide to sell it. This generation Civic has really gone down in terms of quality. Nuisances/flawed in engineering ranged from rattles, blown strut (25K) and dead alternator (30K). For a 80K mile car with a record of 3 accidents (with frame damage), hail damage, and an engine/head that needed to be replaced; I got the better end of the stick when I was offered a 4 grand trade-in value.
My 2001 Civic has the same problem. When it is a hot afternoon and I have the ac on my car looses power and backfires. After it cools off it runs normal. I have the same P1361 code. My question is this. It the ”Top Dead Center” sensor another term for the “Camshaft Position Sensor” or “Crankshaft Position Sensor”, or is it a completely different sensor. I know in the older Hondas the sensor was in the distributer but I do not think my car has a dist because it has 4 ignition coils.
I have that same P1361 error code, I was just wondering if I should change the Camshaft Position Sensor or the Crankshaft Position Sensor. Thanks.
Received 1,443 Likes
Rep Power: 338 Re: P1361 Code, Engine Runs with half the power
decided to delete..
ima bump this cuz this just happened to me i have almost 160k on this car its a 2002 coupe ex. me and this car have been together thur thick and thin. what should i do now
"Thick and Thin" would mean, you just do whatever it takes to keep your friend on the road. Sounds like its a new head....
Driving While Asian
I drive a 2002 Honda Civic EX 5 speed manual tranny & I had the same problem, driving down the freeway, cruisin' at 70 MPH with the A/C on, and the car just lost power, gauges started dropping, and eventually the motor turned off. Pulled on side of road for 5 mins, started back up and made to location i was going to. On way home happened 2 more times, turned A/C off and it was fine. Check engine light came on and when i checked the codes it was pulling P1361. Check engine light was on from the first time it happened until now. I went and bought a new valve cover gasket, and a Camshaft position censor, replaced both and now my car runs like new. Other known problem fixes of this include cleaning the sensor, wiring harness that connects to the sensor, TDC sensor, distributor, & a few other minor things. You can do this by yourself if you have even a little bit of knowledge of how to take the valve cover/timing belt housing off. The sensor is located inside of the timing belt housing under the crank. Make sure when you take off the housing, put a rag or something under the sensor so when you take out the bolt holding the sensor in, it doesn't fall into the crank box. If that happens, you're in for a world full of pain lol. Most of my bolts took a 10MM socket. If anyone needs some help with this, let me know. Willing to help.
Gonna go a head and preface this by saying i'm pretty responsible about changing my oil and this situation is just a lapse in judgement. Okay ....so i'm gonna go ahead and say i'm an idiot. Needed to change my oil about a month before coming home from the semester at college. Light came on and I figured i'd just change it when i got home....that was about a month ago and i figured well one more day isn't gonna hurt it then i started working started summer classes and one thing led to another before you know it its been a good while since being way passed the point in which i needed to change my oil. Today i was driving home from class on the interstate its hot as hell i'm driving with my ac on then bam car starts losing power like its running out of gas gages going haywire losing rpms and engine light comes on. I pull over try to crank it nothing it will only crank and go about a little over 2000rpm so i think i'm ****ed. Try it again and i drive to the next exit with lights on. I park it on the side of the road calling my buddy and i think i'm just ruined. I look in my trunk and i've got a couple quarts of oil. I put two quarts in let it sit for a bit cool down and when i cranked it up again it started to run normally. I drove it straight to a garage to get looked at. They changed my oil and said they couldn't see any major damage like any metal in the oil or anything like that but did say the oil was black as hell. From there i drove to a place that could check my check engine light code. Advanced then read me the codes one of them being a camshaft sensor and two other honda specific codes, one being the p1361 mentioned here. I drove it home decided to park it i even ran an fuel cleaner through it on the way home (five bucks at advance) after a couple hours i decided to take it for a drive and it ran fine no codes. I'm still going to keep an eye on it as i'm really concerned i may have done some serious damage to it. But if anyone else here has this code consider getting your oil changed because as of now it has solved my problem. Still crossing my fingers hoping i didn't do any serious damage
This thread helped me out a lot today so I wanted to post my situation.
Was driving around town, 85 degree day with the AC on and 4 people in my '01 Civic LX. Car went into limp mode, CEL came on and was stalling a lot and running really hot. Even after letting it sit and turning the AC off it still was running gimpy so I decided to just drive it home and diagnose from there.
Let it sit for a couple hours and it started up and ran like normal again so I drove it to the auto-store to get my CEL codes checked. P1361 and P1362 were the codes, TDC sensor. Advance and AutoZone called it a camshaft position sensor in case they try to tell you there is no TDC sensor on the car.
Purchased the sensor and had the old one out and the new one in less than an hour later with nothing more than a ratchet, 3" extension, 10mm deep and short socket and a flathead screwdriver.
I forget where I read it but someone mentioned just loosening the valve cover bolts and prying up on the rights side to remove the upper timing belt cover instead of completely removing the valve cover. SO much easier this way and saved me $30 for the gasket and an extra hours worth of work. Just make sure your careful and don't pry up anywhere underneath of the gasket. I pulled mine up slowly and carefully by the oil cap just enough to slide the timing belt cover out. Really a lot easier than I expected and all my problems and CEL codes disappeared afterwards.
One thing I did forget about was re-learning engine idle. I disconnected the battery beforehand and when I reconnected I got in and drove right away. Make sure before you start it up that all of your accessories and lights are turned off and let the car idle for 10 minutes before you do anything else with it. I had to let the car warm up, turn it off then pull the FI ECU fuse, put the fuse back in and then start and let the car idle for 10 minutes w/o lights and accessories. Fixed my idling problem completely and now she's running like a champ again.
Sorry if I'm rehashing some things already posted here but I know I found a lot of this info in different areas so just trying to make it easy for someone who stumbles into this like I did.
Nine days ago, I too, had my engine "shutoff" (2002 EX sedan, 5spd man.) and then not run above 2K RPM. Got it to limp over to a business parking lot and walked to the Honda dealer (conveniently about a mile away). The Honda dealer didn't have a recovery service so I got my wife to pick me up and take me back to the car. After sitting for about an hour, the car started right back up. The check engine light (CEL) was still on so I drove it to the dealer. They pulled the P1361 (and P1362) code(s), but didn't want to take my $400 to replace the sensor and valve cover gasket. The mechanic thinks that the crankshaft is moving around causing the alarm and if the sensor gets replaced, the symptom will probably come back.
Same symptom occurred again today. After a 30 minute rest, the car ran fine and the CEL went out on its own. I didn't recover the code, but I'll assume it's the same as before.
In both of these incidents, "heat" appears to be a factor. Is it possible that something heat related (vapor lock, fuel delivery problem, etc) is triggering a "TDC incident" (i.e. simply causing the engine to skip of buck)? I find it strange that heat seems to be part of scenario and "cooling off" seems to get things going again.
sprey
sprey
sprey
sprey
If it is a Hall sensor, and they are subject to temperature drift, maybe this has something to do with it (see how dangerous 5 minutes on google can be for someone who knows nothing about "temperature drift in a hall effect sensor")...or maybe simple resistance and heat...not the first sensor I have had go dead in a car because of temperature.
Regardless, other forums mention checking the connectors from the alternator, but I would go ahead and change the sensor....$42 bucks, 30 minutes with minimal tools, to loosen the valve cover bolts, remove the cover of the top of the timing belt to reveal the sensor, unbolt and bolt in the new one (should check that the old one isn't just poorly seated at electrical connector or something simple like this). Watch for the bolts....if one falls into the bottom of the timing cover, you may be in for a bigger problem.
Not sure how else to connect these TDCs with other things you mentioned...basically, the ECM is not receiving the pulse from the TDC sensor...
