100,000 Mile Service
Old 03-18-2008
electric130's Avatar
I don't have the Honda manual. What do they recommend for the 100,000 mile service?
Old 03-18-2008
Re: 100,000 Mile Service
i compiled this off majestic honda. how much is good and how much is BS?
Engine oil and filter - replace
Fluid levels - top off all
Lube hinges, locks, latches, and hood cable
Front / Rear brakes - visual inspection
Transmission fluid - drain & refill
Clutch - adjust if applicable
Battery posts - inspect & clean
Fuel lines, tank, lines & connections - inspect
Suspension mounting bolts - inspect
Tires - balance rear tires and rotate to front; adjust pressure & inspect tire wear pattern
Coolant system - Check level & test protection
Wiper blades - check operation & wear
Park brake - adjust & lube as needed
Front/Rear disc calipers & hoses
Air filter - inspect
Exhaust system - inspect
Power steering system, gearbox, and axle boots - inspect
Adjust valve clearance if applicable
Spark plugs - replace (except platinum plugs)
Suspension, struts & steering - inspect
Brake Fluid - replace and bleed system
Distributor cap & rotor - inspect
15,000/45,000/105,000 - additional cost for cooling system service
Engine timing belt and accessory belts
Old 03-18-2008
Murderjetz's Avatar
Murderjetz is an unknown quantity at this point
"Air filter - inspect"
huh...
I would personally say you should be replacing it, not just inspecting it. and much more often than every 100,000 miles. It would be very dirty by then...
Having a clean air filter helps your gas mileage too.
Old 03-18-2008
2DoorVic's Avatar
2DoorVic has a spectacular aura about2DoorVic has a spectacular aura about2DoorVic has a spectacular aura about
i need to have my serviced since i rolled over 100k. They quoted me around $800 to change the belts, plugs and tune up!
Old 03-18-2008
Murderjetz's Avatar
hmmm...well I'm no mechanic but that sounds terribly expensive =\ was this at a Honda dealership?
Old 03-18-2008
2DoorVic's Avatar
yeah but that was me rounding up and after taxes!
close to $500 something to change all the belts, then i $150 or so for the plugs and tune up, then some more for chaning the fluids!!!
Old 03-18-2008
i'm not worried about the cost as i plan to do it all myself. i'm just wondering what the Honda Manual says.
Old 03-18-2008
lmao, i will search for their maint stuff. i think the only thing that actually counts is the timing belt change. everything else is as you need it. so if you already changed your fluids earlier, no need to do it again.
Old 04-06-2008
Oppjonez's Avatar
Oppjonez is an unknown quantity at this point
Well half the stuff on our cars is so easy to do. The auto tranny, coolant, and plugs. As for the belts I had the mom and pop shop I go to do it and it was like $330 total. That was timing, and accessories belts.
Old 04-07-2008
mines a manual.
Old 04-07-2008
Retired suspension supermod.
robbclark1's Avatar
plugs
timing belt
PS belt if you have it
maybe a water pump
Fluids (if you haven't done it)
Adjust valves (if you haven't done it)
That's about it. This is just off the top of my head though.
Old 04-07-2008
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
change lower arm bushings if you have chance....mine made sound when going over rough surface...it's at 108K now...do civic's need valve adjustment? I thought it didn't....correct me if i am wrong
BTW April is Honda care day, so you can get 40 point inspection free...so get your car checked and don't do anything they say....
Old 04-07-2008
what's involved with adjusting the valves?
Old 04-07-2008
feeler gauge, removing the valve cover, a new cover gasket, and the service book for the tolerances.
Old 04-07-2008
robbclark1's Avatar
bushings suck and should be replaced anyway!
I can see it now
"I'm here for my 40 point inspection"
"Sir, we don't know what to inspect, nothing on your car is where it should be"
Old 04-08-2008
Devani's Avatar
I can see it now
, true true
Old 04-08-2008
got any recommendations? i'm still on the stock shocks too. can't decide if i want to get new OEM's, tokico's or something else. keeping the OEM springs though. don't want a drop.
Old 04-08-2008
you know if it's in the Hayne's manual? or only the manufacturer manual?
Old 04-08-2008
should be in haynes i think, its engine related. get tokico shocks for sure, oem is a joke. even for stock spring it will be good. get the ES control arm bushings so they can do em while the susp is taken off.
Old 04-08-2008
Devani's Avatar
go with tokico shocks.....that's what I have on mine with stock springs...it rides much better with 17 inch wheels...
bushings can be either stock or ES bushings ....IMO I like the softness of OEM and I don't do any autoX so I got OEM bushings....
Old 04-08-2008
A descendant of 2k1civic.com
pheaton's Avatar
100,000 miles? Honda would like if you replaced your spark plugs with nails. Then promptly purchase a new car.
All seriousness though, do the tune up the guys were recommending above. Replace those coolant and heater hoses if you haven't already. My car has 82k and those hoses are in bad shape. I need to replace them pronto.
Old 04-08-2008
my hoses look fine.
Old 04-08-2008
pheaton's Avatar
Are the hoses original? I have a hard time believing they are fine. Especially after seeing mine. Don't just look give them a squeeze, look for cracks, mushy spots, etc.
Here is what mine looks like:
Old 04-08-2008
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
Man I just did my timing belt, power steering belt, alternator belt, water pump, head gasket, replaced the head studs, plugs, coolant. took 3 days for all of this and about 500 bucks later she is running better than ever. I do recommend after 100k U do all of this.
Old 04-09-2008
yep. mine are the original from 2002. mine don't look anything like that. of course, i clean and maintain my engine compartment twice a year at least. i checked mine by squeezing and didn't see any cracks or mushy spots.
Old 12-24-2008
Negro991's Avatar
Negro991 is an unknown quantity at this point
What's up well i have a question real quick i would like to know when do you have to replce all your belts i have a 02civic and have not done none of the belts i have 95000 miles on it
Old 12-24-2008
the timing belt is every 110K normally. the accessory belts are whenever they look bad or start to squeak, could be every 50k, sometimes longer. if they look fine, dont bother. timing belt i would do every 100k roughly, for peace of mind since you cant really see the belt under the hood. also change the water pump and belt tensioner (and crank pulley if you have extra money) when you have the belt changed. they are all very easy to do since you have everything pulled apart anyway. better safe than sorry later if they break.
Old 12-24-2008
I wil fix vBPlaza today
LT2004ever's Avatar
looking at my civic service schedule from my stealership
it sez replace all belts at 110,000miles (timing, all drive belts)
Old 12-24-2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
at 100k i know that you should replace your timing belt and water pump... both are lifeblood of a honda.
Old 12-25-2008
ronaldo9's Avatar
Merry Christmas.....
http://www.spoonhonda.com/SearchResu...9&Redirected=Y
Quick Reply: 100,000 Mile Service
