K24 Frank begins.
Subscribe
Nov 21, 2006
i picked up a k24a4 accord longblock. No tranny. the frank begins.
BONE STOCK K24A4
Hytech Cams
Comp Stge 4 Clutch Kit
12LB Flywheel
pistons and rods installed
Reply 0
Nov 21, 2006
Frankenstein swap?
Reply 0
Nov 21, 2006
k24 with a k20a2 head
byaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhh
Reply 0
Nov 21, 2006
i look forward to seeing more with this
Reply 0
Nov 21, 2006
are there special mounts for the K24 or can u just use the hasport ones? for example i have a A3 swap with hasport mounts if i wanted to go K24 can i use the same mounts. Im intrested in doing this also.
Reply 0
Nov 21, 2006
Quote: are there special mounts for the K24 or can u just use the hasport ones? for example i have a A3 swap with hasport mounts if i wanted to go K24 can i use the same mounts. Im intrested in doing this also.
i believe the tranny mount is different, but hybrid is working on that
Reply 0
Nov 21, 2006
Have fun, want to give us the details of what your planning to do?
Reply 0
Nov 21, 2006
you have to use a k20 tranny. hasport makes a special mount for the k24. and with the k24a4, you will have valve clearance issues. you should have gotten a k24a1
Reply 0
Nov 21, 2006
Well he might have gotten his very cheap like I got mine (< $800) and would be planning to swap pistons down the line anyways.
Reply 0
Nov 21, 2006
nice!
Reply 0
Nov 21, 2006
so k24a1 is the motor to get? with any frank setup get you run the si 5 speed tranny?
Reply 0
Nov 21, 2006
Quote: you have to use a k20 tranny. hasport makes a special mount for the k24. and with the k24a4, you will have valve clearance issues. you should have gotten a k24a1
Whats the status of your build btw?
Reply 0
Nov 21, 2006
Quote: so k24a1 is the motor to get? with any frank setup get you run the si 5 speed tranny?
you can run any k20 tranny. 6 or 5 speed. the problem with the k24 tranny's are that the case is too big
Reply 0
Nov 21, 2006
Quote: Whats the status of your build btw?
my custom pistons and rods are done. they are at the build shop with my sleeved block. i still need my head to get done. i just got a tsx tranny. i am putting those in a type S tranny case with a 4.4 finial= longer gears.
if you look at my profile. i have the finished setup of the block there.
Reply 0
Nov 21, 2006
So when you drop a k24 in what subframe do you use?
Reply 0
Nov 21, 2006
FYI, i hope your not planning ont TRYING To attempt to put a K20 head on the K24a4 every where that i have read on different forums said thats the only engine you cant put a k20 head on.
Reply 0
Nov 21, 2006
well... i had/still have the chanc to get a K20a2 block, engine with tranny for like $500. only problem, needs intake mani... i held of for a few months now, i want it but i dont want to go through the hassle of getting all the parts, but i think itll be cheaper to get a full clip, since i got an Auto and all... so what your 2 cents??? should i get it and get the parts and Frank it, or get it, and turbo it?!
Reply 0
Nov 21, 2006
also i get teh axles, injectors, harness, and brakes, for the 5-lugger if i want.. but i like my rota and dont wanna lose them
Reply 0
Nov 21, 2006
Quote: FYI, i hope your not planning ont TRYING To attempt to put a K20 head on the K24a4 every where that i have read on different forums said thats the only engine you cant put a k20 head on.
It fits, you just need to have aftermarket or TSX, or CRV pistons. The accord pistons will hit the valves of the k20 head.
Reply 0
Nov 21, 2006
Quote: It fits, you just need to have aftermarket or TSX, or CRV pistons. The accord pistons will hit the valves of the k20 head.
yeah i knew about that, but wasnt there also something to do with the oil something lol *cant think of the name.* like a passage not being there or sometihng.
Reply 0
Nov 21, 2006
Yeah, you'll have to do away with the oil cooler passage in the block unless you have a machine shop do it for you.
Reply 0
Nov 21, 2006
Oh hell no bro I did alot of research on the k24's all of them and what works and what wont. I pulled the pistons and rods crank stripped her bare.... im going 13.5:1 Custom JE Pistons with some IB K24 I Rods. Then a Type S head with IPS k2 cams, and a quaife LSD 6-speed Tranny...
Reply 0
Nov 21, 2006
hey honda luver will the EP3 axles fit the frank swaps?
Reply 0
Nov 21, 2006
yeah people do use the type S oil pan and system.. I just picked up an oil pan and baffle from a type s.
Reply 0
Nov 22, 2006
If you get stuck look here:
http://www.k20a.org/forum/showthread...4a4%2Fk20+head
Reply 0
Nov 22, 2006
yeah bro I have been reading thatand asking lots of questions.
Reply 0
Nov 22, 2006
there is also some helpful info in this thread as well. http://forums.clubrsx.com/showthread.php?t=429571
Reply 0
Nov 22, 2006
Quote: hey honda luver will the EP3 axles fit the frank swaps?
Good job on all that research man! the only way i learned was lots of readings and thread searching. and alot of trial and error. usually the only reason i will help people now is if they can prove that they atleast tried to search for their answer and got nothing. hit me up if you need any help.
the ep3 axles willl work perfectly. are you going to run this on pump gas? or is this a track car?
Reply 0
Nov 22, 2006
Pump gas 91 octane V-POWER from shell... nikos from k20a.org was running a 13.5:1 compession k24 on 90 pump octane.
Reply 0
Nov 22, 2006
Quote: Good job on all that research man! the only way i learned was lots of readings and thread searching. and alot of trial and error. usually the only reason i will help people now is if they can prove that they atleast tried to search for their answer and got nothing. hit me up if you need any help.
Thanks for the help bro I will keep you updated on my build up.
Reply 0
