How many running the relay for SF fuel system?
Rep Power: 0 How many running the relay for SF fuel system?
Hi guys. Since I am really close to installing the SF kit (just waiting on the last box to get released from the customs ) I am making sure that I have got everything covered.
For now I was wondering on the fuel system, thinking if I should:
1) Use the relay that would turn on the pump upon boost?
2) Use an on/off switch from inside the car instead of the relay?
3) Hook the pump directly so it will stay on all the time?
What do you guys suggest and what setup do you have?
Thankx!
Thankx!
Rep Power: 0 even though I have had the relay on my turbo kit for a year, I want to know the same ?, my pump lately, when my car idles for about 1 minute the pump starts to get really loud, gow can this be fixed, it sounds horrible
Skyline R33
Rep Power: 0 Buy a NOS pressure sensor and set it at 1psi of vacume. That way at idle and off boost the pump does not get worn out pumping every second the car is on. If you take a long trip and on cruise control wh have the damn pump just buzzing behind you glove box. Open your glove box next time you are driving. You can here it clearly.
Rep Power: 583 Well, i am on my 3rd pump right now and i was on my 2nd relay.
This past pump i blew, i went out and bought a toggle switch and a 30 amp in-line fuse. This way, if i am warming my car up or at a long red light i can shut my pump off.
The relay is there to turn on the pump when it senses boost, right? How many of you have had actual problems with the relay so far?
that is correct............but i did have one relay take a **** on me when i was boosting 9psi. Thank god i had a spare.
Skyline R33
Rep Power: 0 can some one explain the relay. I dont have one. I have a NOS pressure switch that turns on at a set psi/vacume. How does the relay know there is boost. I have heard of hooking methanol to the vtec light. When the car hits vtec it sprays. But our cars engage too low for that. But it would be a good switch for the pump.
Just ideas and questions. I am learning as I go. My next project is learning how to Pnp a head. I bought mine and think could have done just as good or better.
the relay does not sense boost. The relay just turns the pump on when the ignition is turned over. The fmu senses boost and will adjust for the increased fuel pressure.
If you notice on the SF fuel system, there is a aluminum tube that runs from the "In" to the "Out".........this is a bypass. The bypass will allow fuel to go to the rail when not in boost and also if the booster pump breaks.
As far as running methanol when vtec is engaged is completely unnecessary. The stock ECU is programmed to supply the proper amount of fuel when vtec is engaged. Besides, any obd II car will supply enough fuel for a 35 shot of n2o.
As far as porting your head, it really isn't that hard. You just need the proper tools and some knowledge of what you are doing.
Here is a link for some info.
http://racingknowledge.org/topic.asp?TOPIC_ID=1497
also, I think I recall reading that having the pump turn on and off frequently could wear it out faster.. is this true?
Skyline R33
on using a pressure sensor to turn the pump on only when its needed. how fast does that pump come up to full pressure. say if you drop the hammer and spool up 7psi the pump needs to come up with 70psi of fuel pressure right quick. I assume it runs up pretty fast but i wonder if there is any delay at all.
New Member
Rep Power: 0 ^ is my friend who helps with my problems/needs with my car
he knows a lil' something something...btw, he's running 13.0 in his SRT4 with just $1500 MAX in mods...I know there is a thread on this (SRT4's) in the track/speed/strip section...
Wait a sec, you got me all confused again. If the relay only turns on the fuel pump when you turn on the car, this would mean the pump stays on all the time whether or not the car is under boost? am I right? This would mean that you would hear the humming kinda sound from the pump all the time ???
ding ding ding....we have a winner ....tell him what he has won bob
a ice cold
a ice cold
a ice cold
ahhhh, I thought the relay would turn on the pump ONLY under boost. Guess I was wrong. So why not have an on/off switch instead ??? At least that way the annoying sound of the pump wont be there when driving in traffic where no boost is required ..... what do you think?
ding ding ding............we have a winner again.......damn, u are good at this game
I ran the power wire from the left red screw in the fuse box and installed a toggle switch near my cig lighter. I also installed a 30 amp in-line fuse too.
If i am letting my car warm up/cool down or am sitting in traffic, i just shut the damn thing off.
Rep Power: 0 Wonder if there is any downside to it (turing the pump on and off). A friend of mine has done this to his boosted 6th gen and when he turns the pump off the car acts as if its getting less fuel but then in a few mins it gets back to normal.
CarStuff
12-06-2020 12:52 PM
