tiptronic civic engine swap
Pro Skater
Rep Power: 0 tiptronic civic engine swap
alrite i was thinking about this...i want to get the base rsx swap.. the auto one cause i have an auto now.. if i swapped that could i also swap in the tiptronic tranny.. its really run to use and i think it would be cool to have a tiptronic civic cause like noone has one haha.. so basically if i did that swap could i do the tranny too?
Rep Power: 377 i was gonna ask this question some time ago but i didnt want to read people bitchin' about swapping from one automatic to another automatic, lol.
Jam out with your clam out.
1 Post
Rep Power: 487 in all reality with both engines being of the k20 make, in theory if you really wanted, you should be able to swap in the type-s engine and the base model transmission should bolt right up to it.
Pro Skater
Rep Power: 0 ^that would be sweet.. alrite because i always like the tiptronic tranny and if i did the swap i did want to keep my boring auto at least u can somewhat shift with that tranny at least i kno i like it...
Rep Power: 0 Other than fabricating a transmission mount, the big issue becomes the wiring and electronics. I can be done of course, but you will use the ability to use a Hondata modified ECU. This may put limits on additional engine modifications, or the ability to use a Type S engine.
If you're serious about doing this, I suggest doing some research on the matter by purchasing both the RSX and Civic service manuals. In the end it would also be a good idea to buy a wrecked RSX with everything you need since this will probably entail major modifications to the cabin harness.
brian g
brian g
BOOST JUNKY
Originally Posted by deciuss
auto can shift faster then a human, level ten makes things that you can add to your auto tranny and you press a buten and it shifts.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
beneditti
01-15-2016 12:31 PM
BREADFAN
04-15-2015 08:58 AM
