Alignment after lowering?
Old Jul 29, 2002
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
How important is an alignment after i lower my car??
Old Jul 29, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
well that depends how you like your tires. [IMG]i/expressions/face-icon-small-wink.gif[/IMG] You need one after you lower.....best thing to do is wait a week and let the springs settle a bit then get your alignment. don't wait any longer and if you drive it a lot then get it sooner.
Old Jul 29, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
you must get your car aligned, it will pull to one side, and your tires will disappear quickly.
Old Jul 29, 2002
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
get an alignment and save yourself from buy new tires in about a month
Old Jul 29, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
I went a year without allignment with a 2" drop & the car never pulled........But they were worn on the inside to hell..........[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jul 29, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: Tekniq
I went a year without allignment with a 2" drop & the car never pulled........But they were worn on the inside to hell..........[IMG]i/expressions/face-icon-small-sad.gif[/IMG][hr]
Yep, gotta have the camber kits...
Old Jul 30, 2002
y2k2ciVic's Avatar
y2k2ciVic is an unknown quantity at this point
i dunno if anyone read my post before but if i was in the situation of a 2" drop, how would i convert that to degrees, camber kits only fix to certain degress. How do i figure out which kit i need?
Old Jul 30, 2002
TEKNIQ's Avatar
Quote
[hr]Originally posted by: y2k2ciVic
i dunno if anyone read my post before but if i was in the situation of a 2" drop, how would i convert that to degrees, camber kits only fix to certain degress. How do i figure out which kit i need?[hr]
I have the Ingalls kit with my 2" drop.........You were only getting a 1.75 with the Goldlines, so Ingles should definately have you covered.........
Old Jul 30, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I never got an alignment when I had put my pro kit on. I think the alignment is better now than it was before so I just left it. It used to pull to the right and now its really straight. I've had the springs on for a couple months and my tires are fine. Later...
Old Jul 31, 2002
Pedrito's Avatar
Pedrito is an unknown quantity at this point
i didnt align my car after i lowered it....and its fine...im gonna rotate the tires soon tho...
Old Aug 13, 2002
1955's Avatar
this may help u guys to estimate the camber angle,,i learn this from these guys racing in a dirt track back in H.S...With a good leveler,place 2 objects (i use 2 3/8 sockets) on the leveler with a distance the same lenght as the rim ,put tape to wrap them just once..place the leveler againt the rim and read it then transfer the readin to a large sheet of paper and use a angle measurement and another good ruler to determind the degree,,sound easy cus it is..PS1..not exactly precise but very damn close..P.S2..make sure the ground is also level.... a closed gas station is my favorite choice
Old Aug 14, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Keep in mind that when you lower your car the TOE isn't going to be effected so your car WILL go straight. When you lower your car you're lowering the center of gravity, therefore putting more stress on the suspension. That's why the tires will always tilt INWARD. That's CAMBER. Your car will still go very straight even if you need to adjust your camber. Get your alignments kids. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 14, 2002
y2k2ciVic's Avatar
When i installed my neuspeeds on my accord i didnt tighten the tie bay nut enough, well needless to say 300 buck later they finally figured out why my toe and camber wouldnt stay in form, stupid bolt, remember when doing suspension always cross your t's an dot your i. so do it right the first time save you money and headache later.
Old Sep 6, 2002
ashburn's Avatar
ashburn is an unknown quantity at this point
Amen
Old Sep 6, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
When you change suspension components, you should always have your alignment done. If you want to keep your car within OEM specs, you MAY need a camber kit. The ONLY way to know for sure is to have your car on that big expensive machine that actually measures the alignment.
PAST putting your car on an alignment rack, you are GUESSING! If you really do not care, then don't get your alignment done. It may be toed in, it may have too much camber, it may even pull. Heck, in normal operation, stock cars get out of alignment. And it is common practice to put on a new set of tires and have the alignment checked.
It simply amazes me that some of you will spend thousands on cosmetic items, and forgo spending 60 dollars on something that could potentially make your car safer, and save you tires in the long run.
As for the camber kits. If you car is off, you need them. If you don't mind the increased tire wear, and decreased traction (since in extreme cases of negative camber you actually have less tire on the road). Again, why would you scrimp on something that really matters.
Old Sep 7, 2002
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I didnt get alignment until about 2 months after lowering... Tires were still ok... my car would drive straight but my steering wheel was about 2 degrees to the right... needed rear cambers but front was almost perfect... Neuspeed Sport Springs
Old Sep 17, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
ok i just ordered my springs today. do i have to get a chamber kit. after reading this post i know i have to get an alignment. but what about a chamber kit? if so i gotta call rob back and a kit aswell, i got the goldline sedan version so my trunk will weigh it back down [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 17, 2002
nytejade's Avatar
Yes, you'll need a camber kit to properly align the rear wheels. Hondas (and most cars) factory camber can't be altered in the rear. The kit allows you to adjust it.
If I was you i'd definitely go with the coupe springs. I had the sedan version of the neuspeed springs on my car for a while and it was ugly as hell, so I put the right ones in the rear. I suggest you do the same. There won't be enough weight in your trunk to weigh it down evenly.
Old Sep 17, 2002
Subrage's Avatar
rob at tornactive said that i should go with the sedan since i have a good amount of weight. ide rather have a little too much wheel gap than not enough
Old Sep 17, 2002
DMX's Avatar
DMX
DMX is an unknown quantity at this point
i got the Neuspeed sports drop and i didnt get an alignment...
i seriously dont think u need one.
Old Sep 17, 2002
VNlilMAN's Avatar
The Standard One
how much does your system weigh? i'm hoping 300lbs so that it wont be too high...
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
