Steering Wheel Moving Side To Side??
Old 08-03-2007
IrockCivics's Avatar
A few minutes ago I was taking my mother to work and when I got on the highway I have to go to the left lane so I wont take a wrong exit so when I was going to switch lane there was a 18 wheeler there so he did'nt want to let me past so when I was watching the truck I hit this big *** pot hole I mean hard *** hell after that my steering wheel move from side to side real fast like it shakes alot when I past 40mph, why is that?
Old 08-03-2007
greeen01civic4d's Avatar
Re: Steering Wheel Moving Side To Side??
ur allignment is most likely off, maybe even bent a rim, and threw it out of balance, get balance checked first, especially to have them check for a bad tire, then if that doesnt work get allignment checked, because if u hit this pothole that hard, itll be out anyway, ways back i hit a curb, and it threw out my allignment in like half a second of curbage
Old 08-03-2007
Autocross Junky
Zzyzx's Avatar
Yup, My Money's on a bent rim or a damaged tire (hope for the damaged tire). Though the alignment is more then likely gorked at this point too. But then alignments will make a car pull in a direction, rather then make the steering wheel shake.
Old 08-07-2007
TURTLEonK
Nameless's Avatar
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
What tire size are you running and brand of rim? If it was a big enough pothole and you went fast enough, its more than likely a bent rim.
Old 08-07-2007
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You definitely need an alignment at the least. No matter what else is wrong, take it to a shop and give them $50 for the job. Then try again, if you still have problems then you may need a balance as well.
Old 10-10-2011
DarenL's Avatar
DarenL is an unknown quantity at this point
Steering wheel shakes around 40mph
I have a 01'civic EX lowered on eibach pro kit springs with koni SRT struts,with brand new Yokohama Avid Envigors. I have replaced everything in the front end with brand new stuff.I have noticed that the wheel shakes around 40mph. Steering wheels pulsates and moves side to side.I just went to the shop where i got the tires,just had them rebalanced and rotated and just had the alignment. I just got installed also my new steering rack and the feeling is still there! Does anyone have any suggestions on what it is?
Old 10-10-2011
sl33pyriceboi's Avatar
^it could be many things.
1. do u have aftermarket rims?
2. i would rebalance ur tires
3. ur rotors could be warped
Old 10-10-2011
lazlong's Avatar
Check the wheel bearings.
Old 11-29-2011
plumbingsupplie's Avatar
plumbingsupplie is an unknown quantity at this point
I love your website, it supplies me countless concepts . The customer service has been impressive . Thanks a ton .
bravo79
Suspension
18
02-10-2022 09:52 PM
honda200192
Suspension
10-27-2019 12:23 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
honda200192
05-31-2015 05:57 PM
anddrrey
05-11-2015 02:30 PM
Quick Reply: Steering Wheel Moving Side To Side??
