O1 civic 4dr with 18 inch rims problem
Rep Power: 0 O1 civic 4dr with 18 inch rims problem
Bought 18 inch rims. Trying to figure out what tires can I go with and if 18 inch is the way to go. Also if I should to suspension work like lowering springs and struts. Please help me ...thanks
Received 1,443 Likes
Rep Power: 338 Re: O1 civic 4dr with 18 inch rims problem
what off-set?
if wrong offset, the wheels could interfere with suspension components and not turn, shave themselves against tie rods, etc.
tire - look for correct OD - use 185/65R15 as stock tire
225 is the limit for 7th gen. Some 225 might not fit
