rear suspension and brake line
Rep Power: 0 rear suspension and brake line
2005 canadian civic Si coupe.
I got 2 new quick struts to put behind on both wheels. they seem to not have the right angle to be able to be screwed at the bottom.
Can i use a spring compressor for the back suspension the spin the top to the right angle.
And my driver side rear wheel brake line thats directly connected to the drum brakes is leaking seriously and is not gonna have any brake fluid by tomorrow morning. I guess its a good thing because i can do any line job now. i need to change that small line part thats connected to the rear drum.
Is there a special technique to refill brake fluid or i just pour in and pump the brakes until all is good?
Re: rear suspension and brake line
Front, The top plate is on a bearing, it will spin with a little effort.
Rears need turned? Swap sides?
I might stick the top of the strut up in the hole and start the nuts but not tighten them yet.
Then stick an extension (or tapered punch or prybar whatever will fit) through the bottom bushing to twist the strut body (bottom section) to where it needs to go, just make sure the spring stays seated in its lower perch correctly. It will turn pretty easy.
Refill and bleed using standard procedures. Make sure the rear bleeder screw(s) will open up without breaking off, you may be replacing wheel cylinders if they break off.
Rep Power: 0 Re: rear suspension and brake line
is this safe or OK?
I really had to twist the bottom of the shock to be able to fit it. You can see there is space now between the coil and where it is suppose to stop. IF this is not OK, any other suggestions are welcome.
^That's what I meant about trying to keep the spring seated in its perch..
It's not far off, maybe less than a half inch? IMO it won't really hurt anything and it will probably settle into its correct position after a short time bouncing on some rough roads.
With that wheel off the ground, you might be able to grab that spring with both hands and twist it into position (not all are loose enough to do this but on some cars you can)
morkys
10-25-2015 09:29 AM
bamahat
10-22-2015 12:11 AM
