Will 18's Fit an 04 Civic Sedan Ex??
Rep Power: 0 Will 18's Fit an 04 Civic Sedan Ex??
I was told that 18's would for sure rub on my 04 civic sedan EX but my friend was told the same thing on his 96 Grand Am but he put on 20's with no problems at all!.. so i need to know from someone who owns an 04 civic sedan..
OMNES AD UNUM
Rep Power: 309 assuming your suspension set up is stock and not lowered... yes 18's will fit no problem. even if you got thick and fatty tires, you still probably wouldnt rub unless your trying to. (IE making a u-turn at WOT)
once/if you plan to lower, then think about rubbing.
OT: one post and you joined ever since aug 2004?! haha. maybe you havent been around long enough, but a good reminder is 7.5" is the widest you can go with no problems. as for offset, 38-45 seems about right? idk my offsets yet, still learning on that one.
Rep Power: 0 Thanks, I was pretty sure that it would fit but i just feel better knowing from people who have Civics.. Im going to get 18 inch Konig Unknowns. Yeah I signed up a long as time ago but just never really got into forums till now.
Rep Power: 0 Yeah my 04 Coupe has 18's with 215 35 18 tires, before I lowered it could have gone with 40 or 45 profile tires, just keep in mind that if you go with taller tires than 35's your speedo will be affected. in other words if you go with say 45 you will be driving much faster than your speedo says.
Just your Ordinary, Average Guy... IN A HOT CIVIC!! HAHAHA!!
Originally Posted by mexinaction
i have 18s on my 04 with stock suspension and they fit perfectly, no rubbing at all
7thGen's Loudest Civic...4,000 watts and climbing...
aus10
04-13-2015 09:26 PM
Lightman
11-10-2001 06:44 PM
