Air Conditioning Post issues with air conditioning here
A/C problem
Old 06-19-2015
civicmom's Avatar
civicmom is an unknown quantity at this point
A/C problem
I am having the same issue with my 02 Civic. But the mechanics are saying its the compressor. Its a lot of money that I can not afford right now. Could it be a switch also? I don't want to pay for a compressor and for it not to work also.
It only blows cold air for about 3 mins and then it blows hot air. Any input would be really appreciated!!!
thank you!
Old 06-19-2015
re: A/C problem
Moved post to its own thread.
There are MANY possible causes of an AC problem.
Right now we don't have sufficient info to evaluate your issue.
You will need to make several observations in order for us to guess at your problem.
And remember, all we can do over the internet is guess.
You say it gets nice and cold for about 3 minutes, then blows warm?
Is the compressor clutch disengaged at that point?
Do you have a volt-ohm meter to test with? Are you willing to get dirty to test some stuff?
Old 06-22-2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
re: A/C problem
thank you!
Get a 2nd opinion! dont tell them anything you heard the other mechanic say.
Just let the guy do his work!
Old 06-22-2015
Re: A/C problem
Damn, I fat fingered the title when I moved the post. Corrected now.
Old 06-26-2015
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Re: A/C problem
I did the below...
1. Removed Wheel & Splash Guard to access the clutch.
2. REMOVE Clutch Plate >>> Got a universal AC clutch tool - which was useless to me, as it only wasted time in trying to hold the clutch plate. At last, i used an impact driver & the nut came off very easily - Try the same & save yourself a lot of time.
3. Cleaned thoroughly inside & out (be careful with the tiny washers inside the clutch plate).
4. Put everything back. Been driving it for 2 days now. AC doesn't stop as it used to before. Will check for few more days & let you all know if it dies again (i will change the clutch, if so).
No harm in trying this... Its free of cost rather spending $400-$600 to replace the clutch. Could be temporary too, but worth the savings !
Thanks.
Old 07-07-2015
civicmom's Avatar
Re: A/C problem
Thanks mrohitredd. I'll have to get one of my guy friends to help me with that. Lol!!! That was very helpful tho!!!
I really appreciate all the input!!! I finally have something to go on!!
Old 07-09-2015
alex_nyc's Avatar
Re: A/C problem
how many miles on this car?
.. seek a 2nd opinion!
Old 07-09-2015
civicmom's Avatar
Re: A/C problem
Alex... its got 165k on it. I'm the only owner since brand new.
mikemc422
08-09-2018 05:41 PM
cukaracha
06-04-2015 07:47 PM
g4384063
05-30-2015 11:21 AM
dinsum
05-28-2015 09:30 PM
beveragemp
05-25-2015 07:11 PM
Quick Reply: A/C problem
