security system problem
Old Mar 25, 2003
JAG609's Avatar
JAG609 is an unknown quantity at this point
i messed up my security system once before, took it to dealership and they said i had it in valet mode, so my alarm wouldnt arm. i did it again somehow, and i called back, and no one was there that knew how to fix it. i didnt see anything in owners manual...thanx in advance.
Old Mar 25, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
There's a button on the panel above where your left foot would be when you sit in the driver's sear. Try pressing it once.
-Kre
Old Mar 25, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
Mine came with a seperate manual that explains how it works, check if you have it, its a bit complicated
Old Mar 29, 2003
FSRbikr98's Avatar
FSRbikr98 is an unknown quantity at this point
I did the same thing ot my car and thought it was broken, turn the key two the second position, and within 5 seconds flip the switch to the OFF side, then remove the key and see if it worked, it takes a few tries to get it right.
Old Apr 1, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
anyone know how to re-program keys and immobilizer?
Old Apr 10, 2003
bfitz's Avatar
bfitz is an unknown quantity at this point
There seem to be other ways to fix the valet mode issue, but here's what Honda told me to do.
Unlock the doors, insert and remove key from ignition 5 times rapidly, then lock and unlock the doors with the switch. Try your remote again, it should now work.
Hope this helps.
-Fitz
CarStuff
Dec 6, 2020 12:52 PM
Youshoe
May 22, 2015 09:36 PM
tylerginevan
Apr 27, 2015 12:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
trevaaaa
Oct 10, 2001 01:23 PM
