2002 Civic LX Brake pedal soft but still stops
Rep Power: 0 2002 Civic LX Brake pedal soft but still stops
I have a 2002 civic 5spd and the brake pedal goes down to the floor but it still stops with no problems. I drove it like this for 11k miles and the brakes haven't gave me a problem the brake pedal is just soft. I tried bleeding the brakes many times but it the same soft brake pedal. It's not normal for sure but I have no idea why it's like that. I read some forums online and they said something about a check valve? Btw no brake fluid leaks out. It's all dry. No fluid leaks on the inside and no fluid leaks in the engine bay. Anyone can tell me what it is?
Re: 2002 Civic LX Brake pedal soft but still stops
Have you checked the adjustment of the rear brakes? Drum brakes have springs that pull the shoes back away from the drum. As the pads wear the adjusters should keep the pads close to the drum but if they don't then there is more travel in the brake pedal.
A quick test is to step on the brakes while the parking brake is engaged since it will push the pads against the drums and remove any travel.
When did this problem start? Did someone install calipers upside down (bleeders on the bottom)?
I'd find a spot with loose gravel, drive into it about 5 MPH....stab the brake pedal to make it skid to a stop.
Jump out and look:
See if two wheels did NOT make skid marks. (This check can eliminate half of the system as suspect)
Jump out and look:
Rep Power: 0 Re: 2002 Civic LX Brake pedal soft but still stops
Jump out and look:
Jump out and look:
Received 1,443 Likes
Rep Power: 338 Re: 2002 Civic LX Brake pedal soft but still stops
what is your procedure for bleeding?
there was a guy that sold his car because he could not get the brakes to work, then saw the guy he sold the car a few months later and asked how it was doing - he said it was great, all he had do to was to bleed the brakes...
have a friend that knows and work on cars watch your procedure - I don't know what that guy was doing wrong, but he was doing something wrong.
