2nd gear slipping out when I'm making a turn
Rep Power: 0 2nd gear slipping out when I'm making a turn
As the title says, whenever I'm driving and about to make a turn (sometimes just going from 1st to 2nd) my 2nd gear slips which causes the car to grind the gear (one of the most horrible sounds I have ever heard). I changed the clutch fluid to see if this would help, which it did only slightly. Would a MTF drain and fill possibly fix this issue. I don't have the money for a transmission swap or rebuild.
Thank you in advance.
Received 1,148 Likes
Rep Power: 485 Re: 2nd gear slipping out when I'm making a turn
2nd gear synchro. I'm pretty sure all of us with 01-05 MT civics get that problem. I read that using Pennzoil synchromesh helps the problem, so I tried it, only to discover it serves as a bandaid on an open wound.
1 Post
Rep Power: 176 Re: 2nd gear slipping out when I'm making a turn
Yes that is a likely culprit, but any gear grinding\popping out issues the first thing to eye is all the motor mounts. Remember KISS keep it simple stupid (acronym, not accussitory).
chuffsy
05-15-2015 12:50 PM
Touge
04-26-2015 11:58 PM
Touge
Ottawa
04-26-2015 11:57 PM
Russps
11-08-2001 02:00 AM
