2001 Honda civic check engine Light
Rep Power: 0 2001 Honda civic check engine Light
Ok I have a 2001 Honda civic I bought that was gutless so I installed a cold air intake and bought a 2 in exhaust system with header it has a high flow make believe cat with o2 bung hole I installed and immediately got check engine light said o2 sensor heater malfunction so I replaced o2 and installed a spacer so sensor wasn't sticking in all the way reset ecu and light went out then came back on 20 min later car has way more power and runs good but has anyone successfully installed bigger pipes without getting this light or do I just need to get a real cat and put on went with this setup cause theres no emissions here but and didn't want the restrictions any help appreciated.
Received 1,148 Likes
Rep Power: 485 Re: 2001 Honda civic check engine Light
What's the actual code?
Did you replace the O2 sensor with an OEM sensor, or did you use one of those universal ones that you need to splice in? The 01-05 civics are quite finicky with what sensors you can use.
Rep Power: 0 Re: 2001 Honda civic check engine Light
It is Oem snapped right in the code was P0135 o2 heater circuit before I changed assume its same code I will check today
Checked code and its the same bank 1 sensor 2 heater circuit malfunction this is with a brand new oem sensor and put a spacer on it how can I get rid of this light
Xuhme
21
08-07-2023 03:40 PM
ashleymmackey
04-18-2015 09:48 PM
bahena08
04-11-2015 05:09 PM
