Clutch Stuck
Rep Power: 0 Clutch Stuck
Hey i've searched and found that there are similar problems out there but mine is a bit different. I've noticed my clutch pedal getting stuck to the floor while shifting and i'd have to pull it back up with my foot but now it sinks completely down to the floor wen i throw it in first gear therefore causing me to always stall. I can pull it back up however and it only gets stuck wen i release the clutch slowly. i've checked my fluid level on the cylinder and realized that its still full and there aren't leaks. I'm not really sure what it can be that makes my pedal sink.. ive also sprayed some lubricant where the line comes thru the firewall to the clutch pedal. Any suggestions guys? I'm thinkin i should bleed it but im not too sure about doin anything until i get some suggestions. Thx
Re: Clutch Stuck
Now thats scary ... em try using some WD40 underneath where all the links are at ... Did u have the sqeak problem before this happened ? did u ignore it for like a long time? get it checked by a mechanic coz it sounds dangerous man !
stay safe
stay safe
Rep Power: 0 Re: Clutch Stuck
i've lubed it underneath b4 .. and yes it did squeak.. and yes i did ignore =/ .. and i may have to take it to a mechanic .. i just wanted a few suggestions b4 i lose moneyy .. thx!
Re: Clutch Stuck
hmm did u try lubing it again ? does it help ? try giving it a bath of WD-40
Im kidding ... the forum is usually dead on weekends so hopefully u'll get some response tomorrow by the pros. I wud say dont worry abt loosing money and get it fixed coz that **** is dangerous ...
Sounds like either your master or slave cylinder has gone out. You'll have to get it diagnosed to see which one it is, but they shouldn't charge more than an hour of labor since it's a very easy job to replace either one.
Parts aren't that expensive either, Majestic Honda carries them both. Master cylinder goes for $84 and the slave cylinder goes for $44. Parts #5 and #7 respectively on the diagram. So all in all even if they replaced them both, you shouldn't be paying anyone more than $200 to do the job. If they quote you more than that, tell them to stick it, and do it yourself.
mrohitredd
40
09-09-2017 12:03 PM
mjdiaz89
06-21-2016 09:26 PM
JetsterDajet
08-15-2015 08:07 AM
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
