Automatic Transmission Fluid change questions:
Old 12-13-2006
CivicsRdBest's Avatar
How much are they and could I get one at Jiffy Lube? I was recommended to get one the last time I got my car checked. How often should they be done? I'm not near my manual so I don't know. Do they affect gas mileage or is the dropping weather affecting my mileage?
Old 12-13-2006
omgwtfbbq mod.
spoonEM's Avatar
Jiffy Lube =
Old 12-13-2006
The World Is Yours!
burke420's Avatar
well..DIY! and only use Honda ATF!, i used castrol=CRAP! dont compromise. get Honda gen. ATF! all other is bad for you or your car. but get it lifted, find the bolt, remove, drain, refill, and roll... easy, but a lil time consuming.
Old 12-13-2006
goodtimes's Avatar
Yes its simple to drain and fill your atf go buy 3qts of honda atf, and do it yourself if you have all the right tools and if not just go to jiffy lube.
it wont affect anything that you menshoned.
Old 12-13-2006
The World Is Yours!
burke420's Avatar
btw, average tranny flush is usually like 60K i think, but i do like 30 since fluid change isnt too hard. plus cleaner fluid is always better. you can never change too much i assume!
Old 12-14-2006
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
I did mine here at 45k, took it to honda and it cost damn near $200! F-ing joke! I assumed they had to do that **** with a machine so I didn't even wanna bother trying it myself.....Guess i will next time!
mattdoc
03-14-2017 12:10 PM
RIPSAW
11-06-2015 04:36 AM
mrohitredd
05-28-2015 10:03 AM
cruisers10
05-12-2015 10:46 PM
bsmiley
04-27-2015 01:27 PM
Quick Reply: Automatic Transmission Fluid change questions:
