2000 Civic EX Passenger Window Won't Work - Replaced Regulator
Old 03-29-2015
sexyscs's Avatar
sexyscs is an unknown quantity at this point
Red face 2000 Civic EX Passenger Window Won't Work - Replaced Regulator
My 2000 Honda Civic EX Coupe has a problem with the passenger window. It was stuck in the up position. No sound when either switch was pressed. I checked the fuses, they are fine. I replaced the window regulator, and it still will not work; not the driver's side switch nor the switch located on the passenger door. I am assuming at this point it is a wiring issue. Am I correct? Does this model have a common problem with wiring for the windows?
Old 03-29-2015
Re: 2000 Civic EX Passenger Window Won't Work - Replaced Regulator
Common problem is broken wiring in the door jamb area of the harness. Drivers door is most used on most cars, so the most common problem area.
Break out a meter and a wire diagram!
rcolosi
04-29-2015 07:48 PM
bsmiley
04-27-2015 01:27 PM
Richkid23
04-19-2015 12:53 PM
tattedlariat
04-12-2015 07:55 PM
mwwhonda
11-07-2001 07:24 PM
Quick Reply: 2000 Civic EX Passenger Window Won't Work - Replaced Regulator
